How easy is it to change a 2wd to 4wd?
Old Nov 29, 2008 | 05:48 PM
mercurygreyrsturbo's Avatar
mercurygreyrsturbo
Default How easy is it to change a 2wd to 4wd?
hi, just a quick question, how easy is it to make a 2wd sierra cosworth shell inot a 4wd shell? just wondering what is needed. many thanks
Old Nov 29, 2008 | 06:08 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
The shell is pretty easy, the only 2 areas you need to touch are the tunnel (drivers side at front) which can be done with a hammer or by welding in a section of a 4x4 (or make something up). The other area is the front chassis legs....the chassis legs foul on the driveshafts if you ever hit full compression on a front shock, so they need notching out. Ford did this on all the 4x4 shells so just have a look at one.
Some people will tell you that you can get away without notching the chassis legs, thats fine I suppose as the risk of bottoming out is low. But if you want to lower the car a lot or hit a speed bump a bit too hard you dont want to run the risk IMO, ford saw it fit to do the mod to the chassis legs so In my book its a required mod.
Dan
Old Nov 29, 2008 | 06:14 PM
mercurygreyrsturbo
what extra parts are needed to covert it?
Old Nov 29, 2008 | 06:27 PM
COSSIE POP's Avatar
COSSIE POP
BORN AND BRED PETROL HEAD
Got some parts here if needed g/box transfere box , front prop sump with shaft oil pump just converted my engine into 2wd as going into pop
yours Ł250 need out the way
adrian
Old Nov 29, 2008 | 09:41 PM
SillyFezzaMk1
Rubber Rhino Crew
Do you have a 200 block engine? If not then you're going to be limited on power you can run through a 205 block in 4x4 trim (200 block is strengthened to take the extra stress from the front drive). Although I wouldnt do it personally; so only recommend on a 200 block engine.
Dan
Old Nov 29, 2008 | 10:01 PM
costina's Avatar
costina
Live long and prosper!!
Also there are stiffners on the rear wheel arches inside of car floor to just below shock mount
Paul
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
