Coil overs(your oppinion)
Old Nov 29, 2008 | 04:20 PM
fordrallycar's Avatar
fordrallycar
Default Coil overs(your oppinion)
Hi All
Do you have any experance with coil-overs good or bad as iam thinking of fitting some to my escort cosworth for road use & witch ones are you useing
cheers paul
Old Nov 29, 2008 | 04:54 PM
charlie luciano's Avatar
charlie luciano
I have avo coilovers on my car, a bit hard even on the softest setting can be a bit creaky on the rear n/s which requires relieving with a mallet can be a pain in the arse if you jack the rear of the car up and then don't get the springs sitting in the cups properly when you put it back down fully adjustable ride height which is good
Luciano
marky_g
Sep 12, 2015 04:26 PM
gcfcos
Sep 11, 2015 06:03 PM
jonfoc
Sep 11, 2015 04:46 PM
dms04
Sep 11, 2015 01:57 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
