4 x 4 fuel relay location
Are these in the same position behind the dash as the 2wd version? (Passenger side)
If not can someone point me in the right direction as I'm trying to help someone out with their problem.
Gary Krishna
If you pop the glovebox out and locate the ecu, you should see a couple relays next to it. one of them will be the fuel pump relay. Look for a fairly thick black with a red tracer wire going to the relay. That will be the fuel pump one.
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
