Biggest aftermarket front brakes in std 3Door rims?
Old Nov 28, 2008 | 01:56 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Default Biggest aftermarket front brakes in std 3Door rims?
Guys,
Im wanting to replace my front brake set up to a slightly larger/better bit of kit, (discs and calipers) but retain the standard 3 Door cos wheels,
What are my options brakes wise, as im not replacing the original 15" alloys!
Thanks
Old Jan 2, 2014 | 03:36 AM
Jasu's Avatar
Jasu
Bump.
Old Jan 2, 2014 | 08:44 AM
wildheart's Avatar
wildheart
http://www.reyland.co.uk/2wd-front-kits/
Old Jan 2, 2014 | 08:58 PM
costina's Avatar
costina
Live long and prosper!!
That's a lot of money..
Shame HI spec don't do a replacement alloy caliper for the 2wd cos to use with std size discs.
Old Jan 2, 2014 | 09:13 PM
cossie daz's Avatar
cossie daz
Speak to mike rainbird at r+b motorsport
Old Jan 3, 2014 | 04:09 PM
Steve the Plumber
Originally Posted by PAUL S
The original 4 pot fronts are a bloody good caliper, just a bit heavy. Decent refurbed set from Big red etc with good pads and quality discs is all you need for a standard or mildly modded car.
Well said Paul, I actually never replaced them in the end, just changed the the discs to grooved ones and changed the pads to yellow stuff EBC ones and dot 5 fluid, did loads of track days without any braking issues apart from warping front discs quiet often, LOL.
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
C2 MAK
Aug 20, 2015 09:46 PM
Aug 10, 2015 12:08 PM
