battery help.
Nov 28, 2008 | 11:16 AM
battery help.
need a new really good battery.
needs it to be over 560A
and idealey it needs to be square terminal.
any suggestions please. need to fit in a s2 escort
Nov 28, 2008 | 11:56 AM
bosch silver top about 50 quid with a 4 year garantee brilliant
Nov 28, 2008 | 12:14 PM
I always get a good one from a tat yard for a mk5 diesel, they are only a tenner, have plenty of cranking power,
never had a problem!
Nov 28, 2008 | 01:50 PM
i put a 097 that i have on mine biggest 1 that would fit in the battery tray
Nov 28, 2008 | 07:24 PM
Go for a Heavy Duty 620amp Calcium Battery from Halfords they are good if your running a heavy sound system I think I paid £50 for it and it fit's ok apart from you will have to undo the two bolts and slide the ignition coil a bit higher then tighted the two bolts again as the battery is a bit longer.
Nov 28, 2008 | 07:26 PM
i ended of getting a 095 from euro car parts which i think is 640A and just fits in the tray
Nov 28, 2008 | 07:29 PM
You got a result there mate how much did you pay for it and was it brand new?
Nov 28, 2008 | 07:31 PM
i knew a geezer who worked there. yeh was brand new and got it for £51.64. i thought that was well cheap mate
Nov 28, 2008 | 10:24 PM
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
TC-ST3
Sep 26, 2015 04:47 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
