Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Fifth Injectors
Old Nov 28, 2008 | 01:01 AM
Walker R.S's Avatar
Walker R.S
Default Fifth Injectors
Hi all, I have recently brought an escort cabriolet for the 1.8zetec Turbo engine that was in it, Upon taking the loom out i realised the positive and negative wire on the fifth injector were joined and connected to the black box on the rear of the ignition barrel. Instead of taking it off the engine completely ide like to know the proper way to fit and wire a fifth injector?? Any1 got any instructions??
CheeRS Walker R.S
Old Nov 28, 2008 | 04:12 PM
muz's Avatar
muz
Wye Valley Hardcore
Mine was wired like that when I bought the car. It basically just pours fuel into the engine from the moment you turn the key. Not good.
You need to buy an ERL MF2 kit. Its a micro ecu that is mappable to supply fuel at a certain point. Say when the car leaches 3,200 RPM etc.
Old Nov 28, 2008 | 08:59 PM
smila's Avatar
smila
mines got mf2 on and it makes abig difference
Old Dec 8, 2008 | 08:12 PM
Phil2002's Avatar
Phil2002
A few years ago i made my own by putting an oil pressure light switch in the cross over pipe(switched a 15 psi) and wired it to a relay and then to the 5th injector so at 15psi the 5th injector would open. not ideal but it worked and cost me under a tenna and took about 20 mins to do.
Old Dec 9, 2008 | 09:36 AM
coswurv's Avatar
coswurv
if you done it like this what voltage injector do you use, is it just wired 12v from an ignition live to relay then onto a injector ?
Old Dec 12, 2008 | 05:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah you need a boost mappable controller so that it only comes on when you need the extra fuel!
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
