What springs
Iv'e got a set of Koni top adjustables on my Escort Cossy. The dampers are the usual Koni yellw and the springs are black. The front sits lovely, about 20-30mm above the tyres, but the rear is way too high, about 50-60mm above the tyres. This set up was on the car when i bought it, so i imagine the springs are Koni as well. The ride is spot on but i really would like to get the back down to around the same as the front. What springs would you reccomend, to use all round.
Webby.
Webby.
Hi,
You can get these from Mike Rainbird. Ahmed Springs are spot on.
thanks,
Manoj
The ahmed springs come in 2 different specs, fast road or Track. I went for fast road as I don't do track days etc. The car looks much better & the stance is spot on.
This thread might help, the Imp blue Cos is mine with the Ahmed springs on.
https://passionford.com/forum/ford-escort-rs-cosworth/249167-shocks-and-springs.html
Deffo Ahmed Springs, i had them on the Saph in fast road form, I have gone for the Track Spec on the Escos to try and prevent the rear end from
squatting too much on acceleration.
SMILER258
Sep 28, 2015 09:04 AM
