Actuator ID & intercoolers
Old Feb 16, 2004 | 05:25 PM
Default Actuator ID & intercoolers
On my actuator the number 91 067
43 0099-17 is stamped on it and also P1.
Can anyone tell me if it is a standard or uprated one.
My car is a 1988 2wd,is the intercooler from a 4wd bigger or is the RS500 model the one to have and does it fit without any cutting ?
Old Feb 16, 2004 | 06:55 PM
richm's Avatar
richm
Hi Mikkel, you new here? welcome, have fun!
that sounds like a standard actuator from those numbers, although the 2wd ones I've seen have been marked -18 rather than -17..
The 4wd intercooler is larger (but similar style) than 2wd, the RS500 one is huge, and mounts in front of the radiator instead of on top like 2wd and 4wd ones.
You can if you wish mount either on your 2wd, although unless you intend to be uprating engine power, it's doubtful you would notice any benefit.. Also worth noting that the RS500 cooler has larger diameter outlets that will not fit the standard boost hoses.
Old Feb 16, 2004 | 08:18 PM
Guinnless's Avatar
Guinnless
-17 is a 12 psi actuator.
Old Feb 16, 2004 | 08:26 PM
richm's Avatar
richm
bad call on my behalf then....
That is a Garrett part number though steve yeah? Where does that sit in respect of a -31 then, psi-wise?
Old Feb 17, 2004 | 11:10 AM
Guinnless's Avatar
Guinnless
-31 is 14 psi IIRC.
Old Feb 17, 2004 | 01:10 PM
richm's Avatar
richm
ah, ok..
So (thinking aloud )where do these 'psi ratings' come from..? A -31 actuator will start lifting at 8psi or so, so i'm curious how it would get referred to as a '14psi' actuator.
On the same scale then, the -17 would be pretty much standard ?
Old Feb 17, 2004 | 05:41 PM
Guinnless's Avatar
Guinnless
Personal experience Rich.
When set with the normal half hole preload and the Amal valve unplugged (electrically) this is what boost I've found they hold.
My -34 will hold 18psi without the aid of the Amal valve on normal preload.
The standard is a -18 IIRC. -17s are a touch stronger.
Does that clear things up a bit?
Old Feb 17, 2004 | 05:53 PM
richm's Avatar
richm
Yes Steve, i get the picture.. I just like to understand the details too
Thank you..
Old Feb 17, 2004 | 09:00 PM
At wich stage is it any use to uprate the intercooler from a standard 2wd
Cheers from Sweden
Mike
Old Feb 17, 2004 | 09:04 PM
richm's Avatar
richm
above stage1 (270bhp/15psi)
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
