Mitsubishi Evo Intercoolers. Differences?
Old Nov 26, 2008 | 01:16 PM
Mike C's Avatar
Mike C
The Special One
Default Mitsubishi Evo Intercoolers. Differences?
Does anyone know if there are any notable differences between the intercoolers for different versions of the Evos?
Forget I-IV
but as for V-VIII do they differ much? And is there any difference to those fitted to specific Evo VIII's? Ie/ Is the 'cooler fitted to the MR FQ400 any different to that fitted to the FQ300 or the 360 etc?
Cheers!
Old Nov 26, 2008 | 01:23 PM
thebigyin's Avatar
thebigyin
i fitted one from a 5 to my 8 and found that while the diameter of the inlet and outlet were the same,the mounting brackets were in slightly different places,needed to use a longer hose on one side and a standard one fitted fine on the other side.
Old Nov 26, 2008 | 01:25 PM
Mike C's Avatar
Mike C
The Special One
Any reason for fitting a 5 to your 8, or just a replacement part?
Old Nov 26, 2008 | 02:10 PM
thebigyin's Avatar
thebigyin
repairing crash damage, had one from a 5 lying about.
Old Nov 26, 2008 | 02:43 PM
Mike C's Avatar
Mike C
The Special One
OK mate, so in terms of performance, there's not really any differences between the versions from 5 onwards?
Old Nov 26, 2008 | 11:10 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
As far as I know and have read, performance wise, no difference in any of the 5-9 Standard intercoolers - as above 5 and 6s had slight mounting differences only.
Old Nov 26, 2008 | 11:39 PM
Red16's Avatar
Red16
This is the way i believe it to be too.
Old Nov 27, 2008 | 12:02 AM
thebigyin's Avatar
thebigyin
the cores look identical,so i doubt there is any performance difference
Old Nov 27, 2008 | 07:35 AM
Mike C's Avatar
Mike C
The Special One
Nice one guys, cheers
Old Nov 27, 2008 | 01:24 PM
sbd16v's Avatar
sbd16v
what sort of power are the standard ones used to ??
Old Nov 27, 2008 | 04:36 PM
Red16's Avatar
Red16
up to 400bhp is about the norm
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
