Different RS Turbo Gearsets?
Old Nov 26, 2008 | 09:34 AM
muz's Avatar
muz
Wye Valley Hardcore
Default Different RS Turbo Gearsets?
Does anyone how what different gearsets there are for the Rs Turbo BC Boxes?
Mines at CTS having an end casing swap for my ARB and the very helpful chap phoned me and said its got a close ratio gearset in it?
I didn't know there was one?
He said he would happily swap it for a standard gearset as they are hard to come across and useful for 1/4 mile boxes to them, and would probably annoy me as it will be loud (semi straight cut maybe?) and have no pull at top speeds, but apart form that didn't tell me much more.
Does anyone know any more about them?
Old Nov 26, 2008 | 10:40 AM
wing's Avatar
wing
the only close ratio gearset i know of is the quaife one and cost £1600 so i'd swop a standard gearset of one
Old Nov 26, 2008 | 05:31 PM
muz's Avatar
muz
Wye Valley Hardcore
So there was no ford shorter gearing? Only a quaife kit?
Old Nov 26, 2008 | 07:22 PM
marky_g's Avatar
marky_g
Fleet Manager
if u have a short set keep them or ask for some money or at least an explanation,
you dont get anything for nothing mate
Old Nov 26, 2008 | 07:24 PM
marky_g's Avatar
marky_g
Fleet Manager
unless its a diesel gear set there very tall but possibly only 1st tho
i'd ask for some money mate, if there straight cut quaift ones or say you want up rate gear set in yours insted
Old Nov 26, 2008 | 07:31 PM
muz's Avatar
muz
Wye Valley Hardcore
Cheers. I'm just not quite sure what in there. He said ,Have you used the box and I said no and he said well the gears in it are close ratio gears which are good for acceleration in a track car, but usless for a road car as they top out quickly and are noisey, epecially on motorways. Do you want us to take them in exchange and they are useful for us to have an dont come up often and we'll swap them for a set of standard gears which will be better suited for road use, but i said no I'll keep whats in there.
Just seemed abit strange that they wanted them, but it was nice of them to tell me.
I origionally took the gearbox in a swap for my old stage 3 Zetec engine plus cash my way and the bloke did say the box had an uprated Quafie Diff, which CTS have told me is actualy just a new ford standard diff and it has been rebuilt so maybe its quaife gears and the bloke who sold it me had his wires crossed?
Old Nov 28, 2008 | 04:05 PM
muz's Avatar
muz
Wye Valley Hardcore
Are the RS1600i gearsets short ratio`d?
Old Nov 28, 2008 | 04:14 PM
B16CVH's Avatar
B16CVH
http://www.rsownersclub.co.uk/car_info/esc31600i.htm
Old Nov 28, 2008 | 04:25 PM
muz's Avatar
muz
Wye Valley Hardcore
lol I`m even more confused now. I phoned them to pay for the casing swap £380 and said do you have any more info on my gearset. They said yah its like a competition set. Used in RS1800`s. And I said Fiesta? and he said no Escort RS1800 I have to go, just see how you get on with it fella. But they never made a FWD Escort RS1800? CONFUSION
Old Nov 28, 2008 | 04:29 PM
B16CVH's Avatar
B16CVH
How much! Just to swap a casing?? Thats a bit expensive, ive had one rebuilt for less than that!
Old Nov 28, 2008 | 06:05 PM
marky_g's Avatar
marky_g
Fleet Manager
ha ha maybe hes charged you to rebuild a rwd type 9 or rocket box see what you get back
Old Nov 28, 2008 | 07:25 PM
B16CVH's Avatar
B16CVH
Id expect an engine to be attached to it for that!
Old Nov 29, 2008 | 09:13 AM
muz's Avatar
muz
Wye Valley Hardcore
I know
End casing + Strip and rebuild, gaskets and seals etc £380 inc VAT
My brother said it sounds very expencive so I'll look at the invoice on Monday when it arrives.
Old Nov 29, 2008 | 04:17 PM
wing's Avatar
wing
if it's a quaife straight cut it will be noisy i've just fitted one to mine
Old Nov 29, 2008 | 09:21 PM
wilky's Avatar
wilky
is it your car that sound's fu**ked ,lol
Old Nov 30, 2008 | 07:23 AM
XR2's Avatar
XR2
There were three different RST gearboxes available. They all had the same gearsets, the only differences:
S1: Final drive of 4.27
S2: Final dive of 3.82, two different gearboxes because of the modified gear lever linkage in ~86
Easiest way to get a very short B5 gearbox:
Use the gear ratios of a GFJ 16V (not sure about the XR2i 16V and the RS1800 that were sold in UK, here in Germany they had a 3.82 axle and short gear ratios, that made them nearly as short as a S1 box) and the final drive of a S1. That's the shortes combination you can get out of Ford standard parts. The RS1600i had the same ratios like the XR3/RST S2 with different 5th gears...
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
