fuel pump question?
Nov 25, 2008 | 11:30 PM
fuel pump question?
My car just randomly died earlier, and my fuel pump does make any noise any ideas? its on a fiesta rs turbo.
Nov 25, 2008 | 11:32 PM
Quote:
Originally Posted by
smerth54
the fuel pump dosent work? just a gess
Nov 25, 2008 | 11:45 PM
yea i know that lol, just wondering if theres a common falt? im thinking the wires come out some where
Nov 26, 2008 | 04:40 AM
fuel pump relay? same thing happand to my series 1
Nov 26, 2008 | 07:37 AM
Just had the same problem with my series 2, bridge the "Fuel Pump Relay" and turn on the ignition, If the pump buzzes then its not your fuel pump but more likely your Fuel Pump Relay". (wouldn't go driving about with it bridged though) Relays are about £30 from Ford - ive seen some on ebay go for over £50 though!!!!!
Nov 26, 2008 | 03:31 PM
nah the fuel pump doesnt buzz, any idea which relay it is?
Nov 26, 2008 | 03:34 PM
also what happens if the relay is bridged?
Nov 26, 2008 | 03:53 PM
i think if i remember rightly the relay is in pasenger footwell on the left behind the plastic. it should click when you turn the ignition i believe? if pump has gone i have an escort cossie one for sale if needed?
Nov 26, 2008 | 05:33 PM
Nov 26, 2008 | 05:47 PM
smerth54
how much do u want 4 it?
£30?
got a chip, t3 and bieges too if interested?
Nov 26, 2008 | 05:58 PM
that sounds gd, i cant afford anything atm really but ill have the fuel pump
Nov 26, 2008 | 06:40 PM
right went 2 have a look and the fuel pump worked then after awhile it died again and now it wont work.
Nov 26, 2008 | 06:42 PM
smerth54
dodgy wiring perhaps?
Nov 26, 2008 | 07:26 PM
yea i traced the wire from under the seat but looked ok but knowin this car its a wire
Nov 26, 2008 | 07:38 PM
the relay in the passenger food well doesn't click ether when i turn the ignition on
Nov 26, 2008 | 07:46 PM
smerth54
try changing the relay mate, most likely that, i believe they normally go when the fuel pump is on the way out
Nov 26, 2008 | 10:58 PM
do u know which one it is cos i think its been bridge cos theres wires cumin out of and it looks like its melted
Nov 26, 2008 | 11:24 PM
smerth54
i honestly couldnt say mate, didnt have one when i sold the shell due to the theft
. the pesron i sold the shell wired the relay up i believe? try a manual?
Nov 26, 2008 | 11:30 PM
yea okiess then m8 cheers any way
Nov 27, 2008 | 05:16 PM
right so if the relay is knackered then when it gets hot will it stop working?
Nov 27, 2008 | 05:49 PM
when the pump is on its way out is sometimes blows relays as a safety
Nov 27, 2008 | 05:52 PM
oh rite oki well ill give a new relay go and see
Nov 27, 2008 | 06:11 PM
just remove the relay power it up and see if it clicks, if it is the relay and the cause was the pump being on its way out it will soon happen again though
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
