S1 Gear selector rod, please help!!!
Old Feb 16, 2004 | 01:26 PM
Default S1 Gear selector rod, please help!!!
I have just had my S1 box rebuilt, but the gear selector rod is badly worn and Ford no longer do that part.
It's the rod that has a joint at the end and selectors to the gears not the one which is fixed.
What are my options, i presume this is a common problem so if i do get a second hand one it could be as bad as this and I think it was a different one they used after 1986.
Can anyone help!!!
Matt
Old Feb 16, 2004 | 05:53 PM
nthorpey's Avatar
nthorpey
remove the whole unit from the car and open the selector box that sits under the gear lever, this is where mine was loose, there is a small rubber ring which wears and needs replacing to make the selection better.
Old Feb 16, 2004 | 06:02 PM
Paddy rst's Avatar
Paddy rst
burtons do a quick- shift comes complete with new gear selector rod and stabilizer rod...expensive tho at £225 .fitted one to my s1 .works a treat..
Old Feb 17, 2004 | 11:31 AM
S1MAN's Avatar
S1MAN
Burton's Quickshift doesn't include the stabiliser bar anymore cos they're obsolete.
Got mine from www.fordpartsuk.com
Good outfit
Colin.
Old Feb 17, 2004 | 02:32 PM
Paddy rst's Avatar
Paddy rst
just as well i got mine when i did then..
Old Feb 17, 2004 | 03:15 PM
Hello all
Cheers for the replies, I have spoken to the guy who rebuilt the box for me (cheap at £375 including a new clutch and removal and fitting I thought) and he recomended 2 places he uses who will refurbish the rod, so hopefully it's going to be all sorted by next week.
He is also doing Zetec boxes for CVH turbos and claims them to be much stronger than standard, reckons it's an easy conversion aswell, so if anyone needs their box doing give him a bell.
Alan 024 76 667211 based in Coventry, not sure what the garage is called.
I will let you know how I get on with the rod just incase any of you need yours doing in the future.
Cheers again for the help.
Matt
Old Feb 17, 2004 | 05:21 PM
S1MAN's Avatar
S1MAN
Matt
Glad that you're sorted.
Remember fordpartsuk when you're after something else , they managed to find me a new stabilser rod and even gave me a discount.
Colin.
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
little bram
Sep 27, 2015 07:45 AM
