which alternator do i have?
Old Nov 25, 2008 | 06:46 PM
xr4man's Avatar
xr4man
Default which alternator do i have?
i have a 1986 3 door. i don't know if i have a 70 or 90 amp alternator. how do i tell the difference between the two?
Old Nov 26, 2008 | 05:16 AM
MARCOSWORTH's Avatar
MARCOSWORTH
You should have 70amp
Old Nov 26, 2008 | 06:52 AM
dojj's Avatar
dojj
Resident Wrestling Legend
there should be a sticker on it, otherwise they are virtually the same physically to look at
there was also a 55 amp fitted to some sierra's, as late as 90 spec cars, but these are physically much smaller
as said, you "should" have the 70 amp version, but the 90 amp one will fit if that's all you can get hold of
Old Nov 26, 2008 | 07:59 AM
The defintive way of telling is the width of the stator gap, between the two halves, but it will be a 70 most likely, but as said fitment same as 90 as well.
Old Nov 26, 2008 | 12:50 PM
xr4man's Avatar
xr4man
i couldn't find the sticker saying what model it was. but we have discovered that i have been using a 70 amp regulator in my merkur with a 90 amp alternator for about 10 years now with no ill effects. so i am thinking that the alternator in the cossie is still the original that came with it so should be a 70. and if it is a 90 then the 70 regulator should still work anyway.
thanks for the info.
Old Nov 26, 2008 | 04:49 PM
Depending on make it will be the same reg/rec unit most likely.
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
