DIY External hard drive........
Old Nov 25, 2008 | 06:12 PM
Redeye Jedi's Avatar
Redeye Jedi
Default DIY External hard drive........
Ive recently given my PC a format and replaced Windows XP with Linux! In order to save the 17gb of music I had collected I have put it onto a second HD prior to the format, that drive was then disconnected and still is! Now I need to get the music back from that drive and onto the Linux HD!
Ive been told about a product which i believe is called an IC box (that might not be entirely correct as it was over the phone)!! Basically this is a box that you can put a normal internal HD into, and with the help of some electronics, gives an external HD with USB connections!! This would be a perfect solution for me as it would make sharing the music very easy!!
Anyone know or heard of these boxes? Ive googled it but none of my search attempts have been successful!
Old Nov 25, 2008 | 06:14 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Just search for external hd enclosure on ebay and a gazillion will come up
Old Nov 25, 2008 | 06:16 PM
Redeye Jedi
Wicked, thank you!
Old Nov 25, 2008 | 06:26 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Just make sure you get the right size.. you get 2.5 and 3.5".. and also atapi or sata connections.
Old Nov 25, 2008 | 06:42 PM
whosyadaddy's Avatar
whosyadaddy
these are the icy boxes you were told about
http://www.advancetec.co.uk/acatalog/IcyBox.html
whosyadaddy
Ooops double post
Old Nov 26, 2008 | 08:32 AM
SapphyMike's Avatar
SapphyMike
I use one of these things with a laptop hard drive I have.
VERY handy!
Old Nov 26, 2008 | 08:57 AM
Adrian's Avatar
Adrian
They are very handy.... I have 4
Old Nov 26, 2008 | 10:46 AM
R4N SS's Avatar
R4N SS
is your drive 2.5" or 3.5"
IDE or SATA
How big is your drive?
You need to know that before you go buy an enclosure. Also need to make sure the enclosure you are buying can accept the size of your hard disc.
Should be able to get what you want for a tenner delivered from ebay.
Old Nov 26, 2008 | 11:37 AM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Back in the day I had an Amiga 1200 with an external hard disk.
The disk sat on the desk attached to a huge long IDE cable that passed through a hole cut in the back of the computer.
We did things properly back then... who needs enclosures & USB.
Old Nov 26, 2008 | 12:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you just need a plug to get power to the enclosure and then a usb lead to hook up to the computer
sridgett
Oct 1, 2015 07:30 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
