need help fast, RS2000
Old Nov 24, 2008 | 09:04 PM
RSTurboSI's Avatar
RSTurboSI
Default need help fast, RS2000
Right people,
I've put a Induction kit onto my mates RS2000 and taped up the secor, started the car and ran fine, drove it to my mates and was fine, gone out and now it wont turn over, the car wants to try start but nothing, So i've removed the induction kit and replace the old air box and put the secor back where its ment to be, whats gone wrong?
HEEEEEEEEEEEEEEEEEEEEEELLLLLLLLLLLP! ME
Old Nov 24, 2008 | 09:11 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
It either turns over & tries to start or doesnt turn over at all - make ya mind up! LOL!
Old Nov 24, 2008 | 09:12 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
whats a secor ??
i had probs with one of my mk5 rs2000's, it was the wire going into the fuel tank, it would stop buzzing and a wiggle of the wires under the back seat would get it going
Old Nov 24, 2008 | 09:13 PM
RSTurboSI's Avatar
RSTurboSI
Engine wont start. its turning over but not firing up
cozzfather's Avatar
cozzfather
C.R.E.A.M.
also do you mean the lights are coming on but theres nobody home ?
Old Nov 24, 2008 | 09:14 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
can you hear the pump buzzing ?
RSTurboSI's Avatar
RSTurboSI
Originally Posted by cozzfather
whats a secor ??
sencor
Old Nov 24, 2008 | 09:15 PM
RSTurboSI's Avatar
RSTurboSI
thats the one.
cant be fuel pump you can here it working.
Old Nov 24, 2008 | 09:16 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
secor or sencor i havn't a fucking clue what one is, sombody tell me
Old Nov 24, 2008 | 09:17 PM
RSTurboSI's Avatar
RSTurboSI
censor thats better i cant spell lmao haha
Old Nov 24, 2008 | 09:18 PM
cossie604's Avatar
cossie604
Think Simon means sensor?
Lee_R21Turbo
Karl............
So whats it missing.....air, fuel, spark or compression??
Also why the hell are u taping up a sensor...or sencor as you call it!?
Old Nov 24, 2008 | 09:19 PM
RSTurboSI's Avatar
RSTurboSI
oh i dont know people im not on this planet, still problems with the car ill worry about my spelling later lmao
Old Nov 24, 2008 | 09:20 PM
RSTurboSI's Avatar
RSTurboSI
Originally Posted by Lee_R21Turbo
Karl............
because it has nothing to tie in with, such as the old air box has a part for it and i bloked it off, looks like a stupid mistake
Old Nov 24, 2008 | 09:22 PM
RSTurboSI's Avatar
RSTurboSI
Karl............
its not missing anything anymore just wont fire up everything is back how it should be and also back how i found it to start with.
all i changed was the air box to an induction
Old Nov 24, 2008 | 09:26 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
i would check for petrol and then drag it down the road on a rope and see what happens, could be its fludid
Old Nov 24, 2008 | 09:27 PM
RSTurboSI's Avatar
RSTurboSI
smells like fuel, when trying.
has a full tank. parked on a small hill.top of the hill
Old Nov 24, 2008 | 09:30 PM
Lee_R21Turbo
....fludid
Sounds like a cowanincedence - nothing to do with the induction kit!!!
Old Nov 24, 2008 | 09:31 PM
RSTurboSI's Avatar
RSTurboSI
Stop with the problems bring me with the solutions
Old Nov 24, 2008 | 09:33 PM
RSTurboSI's Avatar
RSTurboSI
so where do i start????????
Old Nov 24, 2008 | 09:34 PM
pani_k's Avatar
pani_k
PassionFORD Member
So the fuel pump definitely primes and you can hear it? Bump start?
Old Nov 24, 2008 | 09:35 PM
RSTurboSI's Avatar
RSTurboSI
Yeah fuel bump works can here it wine
Old Nov 24, 2008 | 09:36 PM
RSTurboSI's Avatar
RSTurboSI
what will bumping it achive?
Old Nov 24, 2008 | 09:37 PM
pani_k's Avatar
pani_k
PassionFORD Member
Bump start it? As in can you start it by pushing it?
Old Nov 24, 2008 | 09:39 PM
RSTurboSI's Avatar
RSTurboSI
as above mate what will it achive
Old Nov 24, 2008 | 09:40 PM
mikemcc03's Avatar
mikemcc03
check the wires to the coil packs mine done it.. i drive home fine went to start nxt mornin an nothin! there a common problem the signals get interupted an the coil dnt know if there cumin or goin. but u shouldnt have to tape a sensor up to put induction kit on coz thats the idle speed control valve thats bolted to side of air box! only sensor i touched doin mine! but check wires to coils coz the slevein breaks down an they touch!
Old Nov 24, 2008 | 09:42 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
as i said earlier, yank the car down the road either on a rope or by pushing. if the cars got fuel and spark it should go if its phluded
pani_k's Avatar
pani_k
PassionFORD Member
Because if it starts, it might have just been your engine throwing a bit of a tantrum cos it didn't like the induction kit
If there is a serious problem fuel or spark related then it will not start AT ALL. At least if you try to bump start it and it starts then it might have just been nothing. If it doesn't start then at least you know you've got issues.
Old Nov 24, 2008 | 09:53 PM
RSTurboSI's Avatar
RSTurboSI
ok bumping it worked, lmao lmao
Fucker was being a BIG GIRL!!! cars man i hate emmmmmmm!
Old Nov 24, 2008 | 10:04 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
thank fork fa thart
Old Nov 24, 2008 | 10:14 PM
RSTurboSI's Avatar
RSTurboSI
now my next question.
Could i just remove the old panel filter and put the induction inside the air box? so then im not removing the sensor or even the air pipes?...
Old Nov 24, 2008 | 10:20 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
quit while your ahead
Old Nov 24, 2008 | 10:27 PM
pani_k's Avatar
pani_k
PassionFORD Member
See, bump starting it worked! It just didn't like you because you put an induction kit on it
First things first, what induction kit do you have?
And does the engine you have have a MAF sensor?
Old Nov 24, 2008 | 10:41 PM
RSTurboSI's Avatar
RSTurboSI
this one it is
http://www.essexracing.com/product_i...oducts_id=1116
bumping works silly me
And yes it has a MAF Sensor on the side of the air box
engine is a 2.0 RS2000 16v MFI
Old Nov 24, 2008 | 10:43 PM
pani_k's Avatar
pani_k
PassionFORD Member
Ah right, looks like a universal jobby.
Can I see a pic of your engine bay please? In particular the air intake setup. You must make sure the MAF is sealed tight and proper when fitting. This is key. The engine may also take a little time to adjust as well to the new MAF readings.
Old Nov 24, 2008 | 11:17 PM
RSTurboSI's Avatar
RSTurboSI
will get some picture shoots tomorow as its not my car,
Hes gone and brought a nuther one with a MAF sensor fitting with it. so ganna try that, not ganna bother with that one now ganna try the other one, i might try fitting that to my MFI rs turbo IF it fits
Old Nov 25, 2008 | 07:46 AM
Barry R's Avatar
Barry R
You neeed the right 1 for that car boss i had the KnN on my RS2K fooking loved it
Soooo loud
Old Nov 25, 2008 | 08:28 AM
Csm's Avatar
Csm
Bet yer mates thinking twice about asking you to play with the car again
Old Nov 25, 2008 | 09:21 AM
marky_g's Avatar
marky_g
Fleet Manager
that MAF sensor must be connected but with them disconnected they just idel lumpy should effect start
put the filter after the maf it is it like the zetec way? the sensor is on an alloy housing? or its in the air box
best off goin on rs200016v site
Old Nov 25, 2008 | 05:05 PM
mikemcc03's Avatar
mikemcc03
you need the right one for the car because on the air box is a silver valve the HAS to be connected when you buy the right one for the car you get a special plate that you bolt it to.an connect vaccum pipes to from the base that the air filter sits on. on this base theres 2 outlets one for that silver valve an the other for the oil beather on the cam cover. if you need pics let me know an i'll get em for you.
