Fuel computer on right
I been investigating why the fuel consumption computer doesnt work and found that the connection on the back wasn't connected.. I had a look around and saw that it isnt there at all... i had a really good look. I saw an old laserline immobiliser box in there and at first glance thought that they had the same connections but it defo aint...
Has anyone had this problem or any ideas where the bastard could be? Where shall i trace the wires back from?
Ta
Ta
its an 89 mate... i have been reading some previous posts and it seems that it has just been fitted and not wired up... does anyone have the wires and sender units around?
You may be lucky and yours may already have it, or you may be able to pick it up from the fuel ECU, but am not sure on that TBH.
If it was a late EFI-one, you would just go straight to the main ECU for the connections.
Connections (if you get that far though) should be:
1/ Red - +12V
2/ Grey/Green - illumination
3/ Brown/Red - fuel tank sender (separate wire to the fuel gauge where it goes onto the tank)
4/ not used
5/ Brown - Earth
6/ Brown/White - Speed sensor (on gearbox underneath speedo cable)
7/ Brown/Green - Fuel flow sensor
8/ Brown - Earth (connected if MFi, disconnected if EFi)
9/ Black/Yellow - ignition +12V feed
On EFi models
Same as MFi, except pin 7 goes to pin 17 on the ECU
This is all going from memory though
