water in escort car boot?
Old Nov 24, 2008 | 06:20 PM
rst in breaking's Avatar
rst in breaking
Default water in escort car boot?
ive replaced the boot seal and still leaking , just wondering if people have had the rear window seals leak before?
Old Nov 24, 2008 | 06:28 PM
Turbo-Beal's Avatar
Turbo-Beal
You havnt got one of your sunroof drain hoses come off? Just a thought
Old Nov 24, 2008 | 06:32 PM
.Pete.'s Avatar
.Pete.
mk6 Escort Cab
the window seals can leak, and water can get into the boot from the rear lights seals too.
Old Nov 24, 2008 | 06:34 PM
rst in breaking
no sunroof on the car and car is out of way fro direct rain hitting lights aswell as under car cover lol, guess next bet is new glass rubber lol, cheers
Old Nov 24, 2008 | 06:35 PM
RS20004x4's Avatar
RS20004x4
the main problem areas for the escorts are, rear light gaskets, rear bumper bolts, sunroof drains, rear washer jet leaking, or corrosion around the spoiler on the boot lid.
more than likely the rear light gaskets are leaking, sit in the boot and get a mate to spray the car with a hose and see where it comes in from.
Old Nov 24, 2008 | 06:36 PM
Turbo-Beal's Avatar
Turbo-Beal
Must be quite a bad leak if you have a car cover on aswell.
Old Nov 24, 2008 | 06:41 PM
rst in breaking
its not a waterproof cover, just stops people looking and keeps dirt off . wanted to hose it down but has no engine at the minute so isn't really movable
Old Nov 24, 2008 | 06:47 PM
RobL's Avatar
RobL
my old one was leaking in the boot
it was coming from the bottom corner of the rear window ,it was rotten inside the window rubber
Old Nov 24, 2008 | 06:48 PM
rst in breaking
its just appears to end up in the spare wheel well?
JoeyBoyden
Jan 4, 2024 02:36 PM
j.hammond1
30
Oct 31, 2021 05:28 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Old ford
Jul 31, 2015 06:50 AM
