wheres the cooling system bleed screw?
Old Nov 23, 2008 | 10:02 PM
ikarma70's Avatar
ikarma70
Default wheres the cooling system bleed screw?
as above really
thanks in advance
me
Old Nov 23, 2008 | 10:03 PM
Jay,'s Avatar
Jay,
Sponsor
mines under the kitchen sink mate
what car is it
Old Nov 23, 2008 | 10:05 PM
Cozziekid's Avatar
Cozziekid
Erm, what car?
Old Nov 23, 2008 | 10:06 PM
mechanic28's Avatar
mechanic28
what car is it
Old Nov 23, 2008 | 10:08 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
anyone used the vaccum jobbie for bleeding coolant systems?
Old Nov 23, 2008 | 10:23 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I've used a gun type thing before, You hold it at the rad cap and press it, it blows the water through the whole system and then the gun makes a noise its done. Quite smart
Old Nov 23, 2008 | 10:29 PM
mechanic28's Avatar
mechanic28
yer they are well good
Old Nov 24, 2008 | 09:28 AM
RichieST's Avatar
RichieST
Its normally at the highest point of the cooling system, but will help if you can tell us what car....
Old Nov 24, 2008 | 01:12 PM
ikarma70's Avatar
ikarma70
ooops forgot that bit,its a fiesta 1.25lx 1996...would like to know still even though i have bled the system after replacing the heater valve and just took the expansion tank cap off with the heater on full blast and run the engine for 15 minutes keeping an eye on the temp gauge.
Old Nov 24, 2008 | 01:17 PM
RichieST's Avatar
RichieST
I dont think these engines have bleed valves. Just do as you did, with heater on hot let it run with cap off until all bubbles are gone! Maybe worth giving the pipes a firm squeeze to make sure they have no air trapped in them
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Chas
Oct 5, 2015 07:13 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
