priming a tdci turbi
Old Nov 22, 2008 | 08:49 PM
morto's Avatar
morto
Default priming a tdci turbi
hello all, i should get my new turbo for a focus tdci , ive put a few turbo,s on before but never done a diesel before, do you do the same as you would a petrol engine and turn the engine over with the coils off till the oil light goes off and do this a few times
thanks
andy
Old Nov 22, 2008 | 09:43 PM
boost mad's Avatar
boost mad
they are self priming. Although you should do your best to fill the fuel filter before turning over as the tdci pumps dont like to run dry
Old Nov 23, 2008 | 08:23 PM
morto's Avatar
morto
thanks mate
Old Nov 23, 2008 | 08:43 PM
Stu @ M Developments's Avatar
PassionFords Creator
Whatever you do, don't crack the damned injectors off, you could end up seriously damaged. LOL
Old Nov 23, 2008 | 08:59 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Am I missing something here....why would he crack the injectors open if hes trying to prime a turbo!!??
Did you get a syringe of oil to fill the turbo with prior to starting the engine...if so use it!!!
Try using the immobiliser to stop it from starting - i.e. remove the transducer from the key if you can so you can turn it over without it catching!!
Old Nov 23, 2008 | 09:20 PM
Long story, search on PF for the chap who did that to stop it starting. ROFLOL
Old Nov 23, 2008 | 09:24 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Old Nov 23, 2008 | 09:29 PM
Lee_R21Turbo
Oh lord!!! Injector diesel poisoning!!! LOL!
Old Nov 24, 2008 | 08:00 AM
morto's Avatar
morto
ok just got my new turbo this morning and the intructions says..
FILL TURBO INLET WITH OIL UNTIL OIL STREAMS OUT OF TURBO OIL FEED PIPE BEFORE FITTING TURBO
CRANK ENGINE UNTIL OIL STREAMS OUT OF TURBO OIL FEED PIPE BEFORE FITTING TURBO
AFTER FITTING TURBO CRANK ENGINE FOR 30 SECS, TO BUILD OIL PRESSURE
anyone now the best way to crank my focus tdci with out it starting? eveidently its diesel , what about unpluging the ecu
thanks
andy
Old Nov 24, 2008 | 09:06 AM
morto's Avatar
morto
update on this, just been to main ford dealership and spoken to a mechanic, he says as long as you prime by hand they would start it up and not rev it
Old Nov 24, 2008 | 12:50 PM
boost mad's Avatar
boost mad
oooops
I thought he meant after changing the fuel filter
* note to self, read twice before posting *
Old Nov 24, 2008 | 12:58 PM
Lee_R21Turbo
....as above maybe?
Old Nov 24, 2008 | 01:05 PM
kev 3dr's Avatar
kev 3dr
As per Ford instructions thats all ive ever done on cars or trucks petrol or diesel !!
Allways told that as a apprentice and also on a couple of main agent courses over the years !!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
