mk5 fiesta rs turbo project
at larst my rst come out the garage next week hopefuly be at southend on sat with full 11lb noz tank and new stage 3 turbo to bed in . it runs 2bar 30psi i gess iam a boost junky as i ran 2.5bar in 1st rst. But point in hand mate has killed clutch and box in mk5 fiesta and we plan to do rst converion
He will lose air con and we will have to change ps rack. does anyone know if the engin mount are the same as mk5 escort as there are plenty of rst mk escorts and whot drive shaft to use and if frunt wheel plan the same. Is it poss as he is buying donna car ? thanks
when i put a rs turbo engine in my zetec s i used a fiesta mk5 td gearbox (starter motor is in the correct place for the cvh) i used a escort mk6 long one piece drive shaft (zetec), 1.4 escort mk5/6 power steering pump,alternator and crank pully and a t3 turbo, i made up a mount and welded it to thr engine bay and just used the cvh mount, (simple) and just made up a loom so the zs loom was not cut! good luck and feel free to pm me if you need any help...
paceo
Feb 3, 2016 10:31 AM
paceo
Aug 27, 2015 12:45 PM
