just had a thought!!!!
Old Nov 22, 2008 | 12:35 PM
mechanic28's Avatar
mechanic28
Default just had a thought!!!!
Yes amazing i knowbut i am bored at work!
just brought a complete 4x4 inlet plenuim(off dan@rapidfords top bloke!) with everything i need to swap it on to my 2wd even got the o.e fuel pipes uncut!which my 2wd has not
But will the pipes off the 4x4 rail/regulator reach/fit the original 2wd pipes coming from underneath the car?
And how do i get the pipes off from the one coming from the pump and the return one?i could just cut them i know but would like to knowe how you remove them!Or is there a special tool?
Old Nov 22, 2008 | 04:40 PM
mechanic28's Avatar
mechanic28
up!
Old Nov 22, 2008 | 05:05 PM
lee2cossies's Avatar
lee2cossies
Theres a special tool to remove them,but you could try warming them up with a heat gun an prising them off.The easiest way is to cut them.Did you get the rail and regulator ? as these are different.I done it to mine and the pipes were plenty long enough.If not its just a case of pulling the rubber pipe off the metal pipes that run under the car and replacing with a longer one.
Old Nov 22, 2008 | 05:20 PM
mechanic28's Avatar
mechanic28
yes mate got everything regulator,rail etc!still has the o.e high pressure pipes connected to the rail/regulator the pipes are in perfect condition just hoping they will reach my metal pipes that go under the car!
so you need a special tool to remove these pipes then?(where they connect to the metal pipes?how would you get the pipes off the fuel rail as they look like they are heat shirked on?or does the special tool do this part as well?
Old Nov 22, 2008 | 05:25 PM
STUCOS's Avatar
STUCOS
Yes mate,special tool,to seperate plastic pipe from metal pipe,a1 sell the tool but it's Ł25
cheeRS stu
LHD220Turbo's Avatar
LHD220Turbo
the incoming fuel line onto the rail had me baffled me for ages - ideally you need air con tool - these below
You can if you're careful spring them open with a thin bit of metal wrapped around the pipe and slid up; its a sping lock clip - fiddly buggers
http://www.justoffbase.co.uk/Air-Con...=9&category=90
Old Nov 22, 2008 | 05:34 PM
mechanic28's Avatar
mechanic28
cheers for the replies chaps!i have got some of them air con tools at work!think i might buy the tool tho !as i will have to take to pipe off at some stage!
will the pipes from the 4x4 rail reach and fit ok to the metal pipes?as i do not know if the o.e 2wd pipes are routed different?also i presume to check the fuel pressure you simply undo the regulator and put you gauge in the same way as you would a 2wd one(inbetween regulator,rail!)
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
gingeRS
17
Oct 2, 2015 09:42 AM
