Alternator Charging Voltage?
Old Nov 22, 2008 | 10:37 AM
Sonic Boom's Avatar
Sonic Boom
Default Alternator Charging Voltage?
When my 3 Door is running at the moment the Voltmeter reads 13.6 and then drops to 13.1 when you put the lights on.
Does this sound a little low? I swear it used to charge at about 14 Volts a while ago.
Just wondering if the alternator is on the way out.
Rich
Old Nov 22, 2008 | 11:04 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
sounds fine mate,
if you fancy a job which will better the charge, replace to alt-battery wire, as it gets cooked by the turbo and gains resistance.
jay030787
Sep 18, 2015 04:38 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
