focus 2.0
Old Nov 21, 2008 | 08:39 PM
woolford's Avatar
woolford
Default focus 2.0
had a few small problems with my family car when i brake it feels like its going to cut out why is this??? also i changed the plugs and 2 of them where dripping with fuel/oil not sure what??
any ideas??
Thanks paul
Old Nov 22, 2008 | 10:29 AM
woolford's Avatar
woolford
?? is my car going to die??
Old Nov 22, 2008 | 01:47 PM
focusv8's Avatar
focusv8
any ideas??
Thanks paul
Probably the coil pack causing both faults, trying to run on 2 cylinders at tick over due to coil pack missfiring.
Old Nov 22, 2008 | 09:16 PM
woolford's Avatar
woolford
how can i sort this??
Old Nov 25, 2008 | 12:29 PM
woolford's Avatar
woolford
bttt
Old Nov 25, 2008 | 03:51 PM
Chris69's Avatar
Chris69
it could be the coilpack meaning its only firing on 2 cylinders properly hence the build up of fuel on the two plugs.
get a new coil pack mate then go from there.
Old Nov 25, 2008 | 04:55 PM
woolford's Avatar
woolford
Thanks ill try this. If not ill be back[
Old Nov 27, 2008 | 08:14 PM
woolford's Avatar
woolford
Done this its stoped feeling like its going to stall but the lights etc still flicker
Old Dec 17, 2008 | 07:12 PM
northenhunk's Avatar
northenhunk
bitten by the rs bug
is the fluid on the plugs oil or fuel and if your not sure how to tell give it a smell or look see if the fluid is thick and black or thin and clear
Old Dec 19, 2008 | 12:42 PM
woolford's Avatar
woolford
im guessing its oil as its black.. i recon the piston rings are to blame any thoughts??
Old Dec 19, 2008 | 12:45 PM
mac456's Avatar
mac456
probably the rocker gasket cover mate if its oil
Old Jan 6, 2009 | 10:26 AM
northenhunk
if the rings were gone there would be loads of smoke out the exhaust getting worse as the oil heates up,
if it is stugling to idle when stood still but running on all 4 cylinders i'd say it was a fault with the idle control valve as these have been shit on fords since they first used them in late 80's early 90's.
btw any fluid on the spark plugs will look black as the cylinders are full off soot and turn everyhing black just like youe exhaust pipe etc.
nico12
Dec 31, 2015 04:42 PM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
natehall
Sep 8, 2015 05:13 AM
