4-2-1 manifolds
Old Nov 21, 2008 | 03:30 PM
juni0r's Avatar
juni0r
Default 4-2-1 manifolds
Need help!!
There is one or two i have my eye on. however i do not know what to do with the second sensor as both only have one mounting.
If i dont use the second sensor the engine light will stay on.
Is there a way around it with out drilling the manifold and welding in a new sensor mount??
Old Nov 21, 2008 | 04:33 PM
northenhunk's Avatar
northenhunk
bitten by the rs bug
either buy one with both sensor mounts in or your gunna have to drill a hole around 25mm then put a nut on that takes the m20 thread of a sensor and weld the nut over the hole, i've done it a few times is an easy job
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
caprixpack
Sep 25, 2015 07:53 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Si B
Sep 12, 2015 06:49 AM
