2wd suspension
Old Nov 20, 2008 | 03:02 PM
bad boy rs's Avatar
bad boy rs
Default 2wd suspension
My 2wd saph currently has standard shocks and springs
gonna be upgrading soon, but what do i choose, what is everyone using
avo, koni bilstein etc ?
also how much of a drop should i go for ?
Old Nov 20, 2008 | 04:13 PM
JoeRS22's Avatar
JoeRS22
grove garage do a nice kit, raises it +60mm rally style!
Old Nov 20, 2008 | 05:09 PM
SOO's Avatar
SOO
i got bilstein -30 mm drop full kit,unsure what one it is but its got nurburgring stickers on it
was previously fitted to a mates car but he changed to coilovers 500 miles after he put them on,his sat really well and handles good too for a 2wd with 330bhp,stuck good to the road
will take pics tomorrow
Old Nov 20, 2008 | 05:24 PM
LHD220Turbo's Avatar
LHD220Turbo
road car or track?
if its track - i'd go for gaz coilovers
it its road - i'd go for Konis (adjustables) with ahmed springs
the ahmed springs lower it about 15mm, dont go anymore than that otherwise they handle worse than standard
Old Nov 20, 2008 | 05:32 PM
bad boy rs's Avatar
bad boy rs
its a road car
was looking on matt lewis e bay shop and hes doing avo kit with -20mm springs for
320 quid, but the konis are alot more expensive.
Will coilovers go straight on a 2wd ?
Old Nov 20, 2008 | 09:05 PM
AndyPen's Avatar
AndyPen
Might have to make space in the rear arches for the springs - just a touch or they'll rub.
pm ing you about the old ones pal
Old Nov 20, 2008 | 10:52 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I'd just stick a set on koni's on mate.
Dont go for too much of a drop or you'll probably make it handle worse.
Got koni's on mine and you know what my car drives/rides/handles like.
I got no complaints anyway!
Old Nov 21, 2008 | 07:51 AM
Coilovers will go on but as said you may need a hammer, just a couple of whacks where you can't see it is all that may be needed, but they are hard set up.
Koni are supremly comfy, even at hardest setting I would use these with std ride height chassis dynamic(avo) springs, still drops around 1 1/4", I have my coilovers set at std height - 1/2", going lower will decrease body roll, but may if you go stupid low put the geometry out too much for grip, especially at the rear.
Old Nov 21, 2008 | 07:01 PM
JoeRS22's Avatar
JoeRS22
Fooking slam it paul!
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
