Rs turbo brakes..... Need help
Old Nov 20, 2008 | 09:24 AM
RSTurboSI's Avatar
RSTurboSI
Default Rs turbo brakes..... Need help
last night i went to bleed my front brakes. the passnager side brakes.
i was trying to undo the bleed niple and it has sheard off, the screw peace is left inside the caliper. its probly stuck in tight and wont move, how do i go about removing the bleed niple out of the caliper?
i can only think of one thing, drill it out?
Old Nov 20, 2008 | 10:54 AM
london_chris's Avatar
london_chris
fraid so, drill it and possibly use a screw extractor, used to be called "easy outs"
http://cgi.ebay.co.uk/Brand-New-5-Pi...3A1|240%3A1318
thats what you could try using, the only problem with drilling them out is that you risk damaging the caliper itself, the extractors u drill a small hole and wind these in and they hopefully unscrew the stuck part, (they screw in reverse)
good luck!
Old Nov 20, 2008 | 06:18 PM
NUTS RuS's Avatar
NUTS RuS
If you drill into it hold it upside down.
Need to reduce the amount of swarf going into the caliper as much as possible.
Old Nov 20, 2008 | 07:14 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
OR slack off the brake pipe tht goes to the caliper,and bleed it to there,works sometimes
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
