Good & cheap diff for 2WD Rallye Car
Old Nov 19, 2008 | 07:38 PM
Brocker's Avatar
Brocker
Default Good & cheap diff for 2WD Rallye Car
Hi mates,
i drive a Sapphire 2WD Rallyecar since some years.
Now im searching for update for my diff., so 170 mph are not needet in a rallye, and the LSD of 25% at standart diff is not really a much.
Im still drive the stock rear beam and axels, whats can be a good optional.
I read some about grapper diffs etc. but dont know anything about them and where i can get them.
Old Nov 20, 2008 | 01:14 PM
LHD220Turbo's Avatar
LHD220Turbo
gutten tag
you could try sending in a message to Marco Polo he maybe able to help you
Old Nov 20, 2008 | 02:17 PM
NEIL A's Avatar
NEIL A
I have a 71/2" gripper diff forsale but it is 3.62 ratio £700
Old Nov 20, 2008 | 03:26 PM
Brocker's Avatar
Brocker
Whats the difference between gripper and stock?
Old Nov 20, 2008 | 03:36 PM
NEIL A's Avatar
NEIL A
Its a cross between an ATS and a salisbury conventional slipper.
It is supossed to run free on the over-run (when not being driven)
and lock and work like a plate diff when under power.
http://www.racecar.co.uk/gripper/
Old Nov 20, 2008 | 04:02 PM
Brocker's Avatar
Brocker
And you think its a good option for a Rallyecar?
Are they comlete Diff. or only buildkits?
Old Nov 24, 2008 | 09:14 PM
markk's Avatar
markk
the gripper unit is a fully plated LSD, nothing like an ATB at all, various ramp angles available as well, ive ran one for years in my rally car - works great, you can just buy the diff unit itself if you want to fit it to your own crwonwheel and pinion.
Old Nov 24, 2008 | 09:36 PM
slydawg65's Avatar
slydawg65
my mate has a gripper on his G3 escort rally car and he swears by it. £700 is a good price too...
Old Nov 24, 2008 | 10:16 PM
james kiely's Avatar
james kiely
what kinda power will the standard 2b diff take,all answers greatly appreciated.
cheers ,james
Old Jan 21, 2009 | 08:23 PM
Grayson's Avatar
Grayson
One option is the Eaton plated LSD, which runs about £275.
The weak point in the stock diff is the spider gear, of which there are two. I know with the Eaton LSD the spider gears are designed with a backing plate that greatly improves the strength, and they are forged and shot-peened. The point? With an aftermarket diff you'll probably support much more torque than stock. If you install a Quaife the spider gears are eliminated altogether and the next weak point becomes the ring and pinion, which members of this board seem to have no trouble with until they're up to ~500hp. Not many people get into that territory.
Old Jan 21, 2009 | 10:17 PM
0sierras0's Avatar
0sierras0
500 hp on road are different than 500 hp on rally use!think of the rally tyres grip.
.i believe that the only solution is 9'' diff because i have tried any cheap
solution on my rally car and every time the same thing ..broken cwp
or cut like bread the half shafts inside diff.my car has 460 hp!
Old Jan 22, 2009 | 02:03 PM
Grayson's Avatar
Grayson
Yeah, regardless of the amount of power you have, if you are performing in a motorsport that is leading to broken ring & pinion gears, then by definition you must move away from the 7.5" differential. You can stick an unbreakable diff in the 7.5" axle, but that obviously won't affect the strength of the ring & pinion or the halfshafts. Fortunately for the vast majority of XR & Cossie owners the 7.5" axle is plenty strong once the differential inside is upgraded.
Old Feb 4, 2009 | 09:47 PM
marco polo's Avatar
marco polo
to be honest the Ford Motorsport 9" unit is the way to go if you can afford it
either uprated VC (600Nm tarmac)or a xtrac plated unit
saying that i have a 450+ 3dr cos with a 7.5" gripper plated diff and i have never broke it , as mark k knows i have had the diff for years the only thing i have done was to have a new set of plates , the plates lasted me about 5yrs that was constant road use and track day abuse
the gripper is a great unit for what your paying it really is value for money and it works and works well
i agree that no matter what 7.5 unit you have either a ATB or Plated diff the weak point will always be the crown wheel and pinion
same goes for the normal standard VC lsd the weak point is mainly the planet gears
atleast the plated diff or the ATB unit does away with these planet gears so there is one less thing to worry about
im lucky enough to own a 9" Xtrac plated unit for my escort cos , but i have never driven with it so i cant say how good or how bad it is
only thin i will say with the gripper you can have it set for what ever you like progressive or full on either way great value for money
cheers marco
Old Feb 7, 2009 | 09:46 PM
0sierras0's Avatar
0sierras0
Where can someone find a 9'' rear diff, mate Marco polo?
Bara only ?I thought that 9'' where Ferguson not x-track...
markk
Dec 2, 2021 06:59 PM
xr4x4rs
Aug 6, 2015 09:03 PM
COLEYST200
Aug 3, 2015 08:55 AM
Old ford
Jul 31, 2015 06:50 AM
