some advice please
were wud i best putting my car battery behind the passenger seat or in the boot i was thinking behind the seat for better weight distrubution or iam i wrong, any advice wud b great thanks
If its a wet cell battery full of acid and you roll the car where will all the acid go apart from down your neck ?
If its a gel type sealed battery then go ahead and fit it behind the seat no problem
get a sealed battery box from any motorsport dealers and put a small vent pipe ie washer pipe out through the floor then u can fit gel or wet battery . your better off fitting it behind the seat i have tried both behind the seat and in the boot in my old track mk4 and found that in the boot the length of the power cable ment it lost carge very quickly where as behind the passenger seat it was fine
mk3ste
Oct 17, 2021 10:09 AM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
