inlet manifolds
Old Nov 18, 2008 | 04:49 PM
cossie0_4's Avatar
cossie0_4
Default inlet manifolds
what would i gain from switching from my 2wd setup to a 4wd also would like to fit a 14mill spacer any views are welcome cheers
Old Nov 18, 2008 | 06:36 PM
cossie0_4's Avatar
cossie0_4
good or bad idea anybody
Old Nov 18, 2008 | 07:02 PM
benporter's Avatar
benporter
only needs changing at around 430bhp, space wont make much defference as its the elbo what is restrictive , 4x4 one come restrictive at around 460bhp iirc
Old Nov 18, 2008 | 07:12 PM
Garage19's Avatar
Garage19
The manifold doesn't just "become" restrictive at a certain point.
Old Nov 18, 2008 | 07:20 PM
spoilt_rs's Avatar
spoilt_rs
Bear in mind the 4x4 being less restrictive, it will flow more air than the 2wd, which means you will need to alter your map to correct your afr.
I'm sure someone will confirm whether or not this is true.
Old Nov 18, 2008 | 07:26 PM
cossie0_4's Avatar
cossie0_4
also will a 2wd fuel reg and rail fit a 4wd inlet or is it better to switch them aswell cheers
benporter's Avatar
benporter
becomes "too" restrictive then?
Old Nov 18, 2008 | 09:19 PM
mechanic28's Avatar
mechanic28
i am doing the same thing swapping over from a 2wd one to a 4x4 one i believe you can fit a 2wd regulator but it is better to get the lot i.e 4x4 reg,and fuel rail etc!i was also thinking of fitting a 14mm spacer!but my power goal is 380-390 so not to sure if needed?
Old Nov 19, 2008 | 06:55 AM
The 2wd and 4wd regs are totally different, they will not interchange as the 4wd bolts on and the 2wd is secured by bracket and pipe.
The whole rail goes on no problem with correct fuel reg though.
The spacer is and issue depending on which cams you use, as it will restrict the power if you don't have enough volume and wild cams, why swedish plenums do so well, not the shape but the volume.
Old Nov 19, 2008 | 07:52 AM
cossie0_4's Avatar
cossie0_4
was going to stay on standard cams so will this be no good for what im looking at was hoping for as close to 4oo bhp as poss with using t34 with 55 housing.if thats the case will it be just as good using the spacer on a 2wd manifold cheers
Old Nov 19, 2008 | 10:15 AM
LHD220Turbo's Avatar
LHD220Turbo
t34.55 might not last long at around 400hp; its possible to achieve but you might be ringing its neck
is the head standard?
you might be better suited to a t34.63, or maybe go t38 route
Old Nov 19, 2008 | 10:22 AM
cossie0_4's Avatar
cossie0_4
as far as i know its standard. so will a 55 housing be no good for 400 cheers
Old Nov 19, 2008 | 10:33 AM
LHD220Turbo
i think you'd be hard pushed to get 400hp out of t34.55 with a standard head
dont get me wrong; you could probably make 400hp; but how long the turbo will last is a different matter - i suspect you'd be ringing the turbo's neck to get that power
mine used to be a t34.55 on a standard head and i was at around 365-370hp - it makes for an awesome road car
why do you want 400? dont chase numbers; i'd rather have a car with 370hp and it drive nice compared to a 400hp car that drove horrible
Old Nov 19, 2008 | 06:26 PM
cossie0_4's Avatar
cossie0_4
i know what your saying m8 just thought about as close to 400 but 370 will be good also do you know if the trumpets are the same for a 2wd and 4wd inlet manifolds cause if they was wouldnt need to take off inlet just switch covers as ive recently fitted a new gasket and its fine cheers in advance.also is the a difference in the throtle body between the two cheers
Old Nov 19, 2008 | 08:15 PM
mechanic28's Avatar
mechanic28
throttle body is the same and no need to change the trumpets!
Old Nov 20, 2008 | 09:50 AM
cossie0_4's Avatar
cossie0_4
so what is the difference between the two covers then and is there any thing else that can be done to it .also st escos inlet is suposed to be even better is this true but it need to be adapted cheers
Old Nov 20, 2008 | 09:54 AM
LHD220Turbo
the depth of the 4wd inlet is bigger than the 2wd
but yeah; the escos small turbo one is the best of all the standard inlets; but they are hard to get hold of and expensive
Old Nov 20, 2008 | 07:17 PM
mechanic28's Avatar
mechanic28
plus i think the angle of the throtle body is better on a 4x4 one etc as said st is the best o.e one
Old Nov 20, 2008 | 07:24 PM
RSCossieGaz's Avatar
RSCossieGaz
at mo im running t34.55 running usual stg3 like 3bar,greens etc but im also looking to upgrade to 4x4 inlet and gonna run greys and re-chip on mine in new year so should see a good 370-80 you reckon?
Old Nov 20, 2008 | 08:18 PM
mechanic28's Avatar
mechanic28
i am on a .55 as well but on light blues i am picking up my 4x4 inlet tomorrow got to get her fuelling and mapped checked after fitting her but i am running around the 370 mark!
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Can't see why not.
Mine runs a 4x4 inlet, T34.55 and light blues and made just over 370bhp on a DD RR peaking at just 25psi.
Steve.
Old Nov 20, 2008 | 08:21 PM
mechanic28's Avatar
mechanic28
but mines better then his gaz!
Old Nov 20, 2008 | 08:29 PM
RSCossieGaz
oi oi you reckon ah
Old Nov 20, 2008 | 08:40 PM
COLEYST200's Avatar
COLEYST200
you can put a 2wd fuel reg and rail on a 4wd but you will have to have a lug welded on as i did . if you look at the photo you can see the lug at the front for the 4x4 rail which i left on just in case and you can just see the new lug that i had welded on hope this helps
Old Nov 20, 2008 | 09:39 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Your not man enough to prove it
Steve.
Old Nov 22, 2008 | 10:06 AM
cossie0_4's Avatar
cossie0_4
have to post result to see if its worth doing m8 cheers
Old Nov 22, 2008 | 06:10 PM
mechanic28's Avatar
mechanic28
just removed my 2wd one tonight i would say the 4x4 one is about 3/4mm deeper but the main difference is how restrictive the 2wd throttle elbow is compared to the 4x4 one!no wonder the 2wd inlets struggle above 350 odd bhp!
the 4x4 one is the one on top
Old Nov 22, 2008 | 10:56 PM
cossie0_4's Avatar
cossie0_4
that looks alot bigger will the 2wd throtle body fit without any mods and have you just taken the cover off m8
Old Nov 23, 2008 | 09:31 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Yes the TB does fit.
Steve.
Old Nov 23, 2008 | 01:37 PM
mechanic28's Avatar
mechanic28
as above striaght swap with the throttle body,and yes i just took off the cover!you will need the 4x4 fuel rail and regulator tho
Old Nov 23, 2008 | 02:11 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
bugger means more time looking on ebay
got my 4x4 manifold last week
just remembered i sold a 4x4 fuel rail last year............
Old Nov 23, 2008 | 06:26 PM
RSCossieGaz
bloody hell thats quiet a difference! im deffo going 4x4 inlet and greys after xmas now
Old Nov 23, 2008 | 06:34 PM
mechanic28's Avatar
mechanic28
Get ya finger out Gaz!
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
