will a erst block fit a frst
Old Nov 16, 2008 | 09:28 PM
andy130's Avatar
andy130
Default will a erst block fit a frst
does the bottom end from a erst fit a frst if not what has to be done to make it fit?
cheers andy
Old Nov 16, 2008 | 09:51 PM
andy130's Avatar
andy130
anyone?
Old Nov 16, 2008 | 10:06 PM
JPA's Avatar
JPA
it will fit but im not sure if the mfi engine has a hole for flywhee pick up ?
i'm sure an expert will be along shortly
john
Old Nov 17, 2008 | 08:03 PM
KEVFRST's Avatar
KEVFRST
It will fit but the FRST block has a hole in for the crankshaft sensor. A good machine shop will be able to machine the hole in though.
Old Nov 17, 2008 | 08:13 PM
andy130's Avatar
andy130
cheers mate is that yours in the pic?
Old Nov 17, 2008 | 08:14 PM
shalon's Avatar
shalon
if you get a erst lump from a 90 spec one am sure they have the hole mate
Old Nov 18, 2008 | 12:29 PM
Kevin_Mc's Avatar
Kevin_Mc
spot-on
Old Nov 18, 2008 | 03:28 PM
andy130's Avatar
andy130
cheers for the help
Old Nov 18, 2008 | 04:46 PM
MarkN's Avatar
MarkN
Don't forget you'll need to change the oil drain pipe stub if your fiesta is still running a T2.
Old Nov 18, 2008 | 09:11 PM
B16CVH's Avatar
B16CVH
The 90 spec S2`s DONT have the hole for the pickup as they never ran a crank sensor, it was only when the fiesta came out and it changed to EFI!
Old Nov 18, 2008 | 09:48 PM
Kevin_Mc's Avatar
Kevin_Mc
later S2s, so only 90-spec (but not necessary ALL of them) had the block with the crank sensor hole in them but still ran MFi - the hole was just that - a hole
Old Nov 19, 2008 | 07:29 PM
KEVFRST's Avatar
KEVFRST
yes andy, Thats my baby.
Old Nov 19, 2008 | 09:50 PM
studabear's Avatar
studabear
you could get a trigger wheel set up fitted to crank pulley to overcome the lack of hole in the block
Old Nov 20, 2008 | 04:35 PM
MarkN's Avatar
MarkN
I've had the hole drilled on mine, - its not a big deal. There is a diagram on PF somewhere giving the exact measurements;- thats what I used.
As has already been said - some late 1990 S2s do definitely have the hole, - but they have a bung in them. Annoyingly they don't get the 36-1 flywheel either; and they can be tricky to find now.
bigryrs
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
