indicators working weird, help?
Old Nov 16, 2008 | 04:53 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default indicators working weird, help?
as above when i rev the S2 or driving it the indicators work, when i dont have foot on accelerator they dont work? what you think it is?
Old Nov 16, 2008 | 05:04 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
weird!
Check the flasher unit is seated properly in the fusebox!
Old Nov 16, 2008 | 05:11 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
flasher unit? what realy in the stalk?
Old Nov 16, 2008 | 05:19 PM
vroooom ptssssh
It Wasnt Me!
flasher unit/relay...its located in the fuse box
Old Nov 16, 2008 | 05:24 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
what colour is the unit?
i know there is a relay in on the stalk i replaced that, it didnt make any differnce
Old Nov 16, 2008 | 05:47 PM
vroooom ptssssh
It Wasnt Me!
I didnt know there was a relay on the stalk? certainly on my S1 the relay in the fuse box was black, just press them all in...must be one of them (if its there?)!
Old Nov 16, 2008 | 05:50 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
ill press all the fusses down in the box, if not ill get a new stalk
Old Nov 16, 2008 | 08:49 PM
johnnysash's Avatar
johnnysash
yep one of the differences between s1 and s2! flasher relay in stalk on s2 in fuse box on s1..... anyways it could be a bad earth? do the hazards work? is it the same on both sides? do you have that lovely escort flashing christmas tree back light effect that we all have?
Old Nov 16, 2008 | 08:52 PM
johnnysash's Avatar
johnnysash
oh and check the voltage at the battery and at the column switch when on tick over and when you rev it up. you might have volt drop on the cables..... even the newest wiring looms are 16 years old now! and hence getting knackered!
Old Nov 17, 2008 | 05:15 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
if it id volt dropping? how can i cue this?
Old Nov 17, 2008 | 06:21 PM
marky_g's Avatar
marky_g
Fleet Manager
check you voltage out the alt mate
Old Nov 18, 2008 | 04:50 PM
johnnysash's Avatar
johnnysash
check the wiring visually for burnage and poor connections (corrosion) and with an ohm meter fpr resistance..... as wire gets older the resistance gets higher due to corrosion. high resitance causes volt drop.
the battery should have over 12 volts with the car running and ideally over 13.5volts
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
RIB1122
Aug 12, 2015 08:51 PM
dlwarrior
Aug 5, 2015 10:19 AM
