Front windscreen rubber seal
Old Nov 15, 2008 | 06:17 PM
BRI308's Avatar
BRI308
Default Front windscreen rubber seal
Does anyone know if these are the same as mk 5 or are they different please
Old Nov 15, 2008 | 08:20 PM
dangerousbrian's Avatar
dangerousbrian
exactly the same..only cabbys are different
Old Nov 16, 2008 | 06:39 PM
BRI308's Avatar
BRI308
thanks brian i thought they were but wasnt sure
Old Nov 16, 2008 | 09:45 PM
svony's Avatar
svony
Where can one of theses? Actually I can use a rear one also. When I eventually have my car repainted I will have to remove what's there and would like to replace them with new ones.
Old Nov 17, 2008 | 03:54 PM
dangerousbrian
i would recommend a ford part only...i have fitted many aftermarket 1s and they just dont sit right in the top corners where the door closes... some fit ok but not worth cos it means pulling the screen back out to change if its a crap fit
Old Nov 17, 2008 | 04:51 PM
fish99's Avatar
fish99
I have a full front and rear windscreen rubber set on top of the wardrobe.. If you need any finis numbers off it for your local dealers then let me know. They should still be avail though
Old Nov 17, 2008 | 05:21 PM
Thrush's Avatar
Thrush
Irritating c........
Ignore - posted on wrong thread
C2 MAK
Aug 20, 2015 09:46 PM
Caddyshack
Aug 19, 2015 07:29 PM
st220kyle
16
Aug 14, 2015 06:13 AM
pegaz
Aug 12, 2015 07:30 AM
