Header Tank
looking for an original 3dr mint header tank - found this one on ebay but looks more like the escort cosworth standard one. looks slightly smaller - is this the case.
http://cgi.ebay.co.uk/FORD-SIERRA-ES...1%7C240%3A1318
cheers
ben
cheers
ben
the link is not working for me but an escos one is the same as a 4x4 saph, they don't have the bit for the coolant temp level sensor as a 3 door cossie will have,
good luck trying to source one, a mint/new one is a bit of a tall order but a decent second hand one which requires a good clean up might be possible, other than that its an alloy replacement item
Luciano
Luciano
Couple here
http://cgi.ebay.co.uk/cosworth-2wd-3...1%7C240%3A1318
http://cgi.ebay.co.uk/cosworth-3dr-r...1%7C240%3A1318
Luciano
Luciano
