oil pressure??
I have recently fitted a new oil pump around a month ago.
however, now I have the oil pressure light flickering when the car is ticking over after a short drive?
the oil feed has been cleared when i did the pump as i know their prone to blockage which can cause the above to happen.
does anyone have any ideas what the problem might be?
just take it steady and if you hold revs just so your throttles just touching but not off if you get me hard to explain you could hear it knocking slightly, well you could on mine
yeah i know what you mean, i shall try that one my home and hopefully i wont hear anything!
mind you if i do at least it solves the problem. :s
thanks
thanks
What oil have you got in it? If its cheap shit, that could be it.
As above check the switch.
TBH is does sound like your are about to get a knock from an unwelcome friend! LOL!
Yes, I dont doubt that!
I have seen two new engines being run in (or just thrashed to fuck truth be known) on mineral oil and this problem happened. Good quality oil and problem solved. Just an idea!
But as you stated, I generally agree it sounds like a bottom end!
SMILER258
Sep 28, 2015 09:04 AM
