difference between a mk3 and a mk3.5
Old Nov 13, 2008 | 09:07 AM
Kevin_Mc's Avatar
Kevin_Mc
Default difference between a mk3 and a mk3.5
what are the differences and which was the RST?!
Old Nov 14, 2008 | 03:43 PM
.Tel.'s Avatar
.Tel.
I can only tell you what I have come across while building my car. I have got a 3.5 shell with pretty much everything from an RST chucked into it.
Best thing to do is take a look through my project thread.
http://www.fiestaturbo.com/forums/my...-rst-vt170008/
Old Nov 15, 2008 | 02:40 PM
fordrs2005's Avatar
fordrs2005
mk3 was the turbo with the flush petrol cap , bigger style wing mirrors
mk3.5 was the opening petrol flap , smaller wing mirrors , different floor pan as double skinned and slightly differently shaped floor ,
there a good few differences but thats just the ovious diffrences
take it your sizing up reshelling a turbo in to a later mk3.5 model fiesta ?
Old Nov 15, 2008 | 02:42 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The shell was modified.. fuel cap doesn't rot etc.. Rear beam is a bit stiffer..
The front hubs are different to normal mk3.. Not sure if they're Puma ones, but they use a slightly larger diameter damper.
They're an awesome chassis.
Old Nov 17, 2008 | 01:51 PM
.Tel.'s Avatar
.Tel.
I've just built mY 3.5 up as an RS replica. Full RS running gear, kit, RS interior etc etc. Selling now as I want a mk1
Old Nov 17, 2008 | 05:01 PM
Kevin_Mc's Avatar
Kevin_Mc
nah i'm just stupid and wondering
Old Nov 17, 2008 | 05:15 PM
RSturboJET's Avatar
RSturboJET
Can't Find 'em? Grind 'em
Mk.3.5 had a stronger floorpan with longer chassis rails, thicker A+B pillars.
It also had: different seat mounting points, fuel cap flap, bigger hole in bulkhead for PAS u-joint, side impact bars in the doors and oval side repeaters.
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
