Mint std/std Crank, 2wd complete head and some other parts
I have for sale:
1x MINT 4x4 crank, std/std , just been polished and checked so is 100% perfect ready to use. £Offers
1x 2wd complete head with all cams, tappets, valves etc. Has been skimmed, pressure tested and measures 138.6mm . Just had all the valves re-lapped in and new oil stem seals. It has some very slight pitting in the No3 pot from a previous meltdown, but is fine to use again. £offers
2x sets of std cosworth conrods
2x flywheels.
1x bottom 2wd crank pulley, perfect bar a small chip out of the rear, about 20mm long, all the timing lugs are there.
£offers on all the above, need a quick bit of cash so try your luck
I have other odds and sods lying about so ask if you need anything
2x flywheels.
May 31, 2016 09:28 PM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
