Slotting the rear beam. Where?
According to the Group N preparation manual I have, Ford suggest slotting the rear beam to allow for adjustment, and then welding a washer in place. I understand that this adds an element of adjustability, but where should the slot be? On the inner rear arm mount? Horizonal? Vertical? I can't seem to figure out where it should be. Has anyone got pictures?
Thanks all,
Charlie
Thanks all,
Charlie
I would first measure what geometry you have at the moment, that will tell you where to make any slot and in what direction.
The ford adjustable arms were just the std arms with the ends cut off and a tube welded on in which sat a heavy duty rod end, and a nut either side of the tube bit securing the rod end in place, thus when the rod end was moved raletive to the arm you have adjustable camber and toe.
M K
Shows & Track Days
16
Nov 8, 2015 06:18 AM
Si B
Sep 12, 2015 06:49 AM
