rst rebuild what headgasket?
I know this has been asked before but what headgasket is best to use? my car only has
kent cvh35 cam, full stainless, uprated intercooler,kn n filter.Iv heard genuine Ford is the best but i rang Ford and they said anything over 200bhp and it will blow? ive also heard payern are good but arnt they just a cheap aftermarket 1? I bought a Felpro 1 before foing 7 miles and my bottom end going but ive heard that done fit properly? any help appreciated cheeRS!
Gen Ford or Cometic if you have the funds.
Felpro = Poo, the fire ring is way to big for a 1600CVH, they are too close to eachother and are prone to blowing accross one another. Had a bad experiance with a Payen, lasted less than 1 mile as the fire ring on No. was faulty
Emtied the entire contents of my water system into the bore.....Oh Joy!!!
Emtied the entire contents of my water system into the bore.....Oh Joy!!!Trending Topics
Yes, we need a sticky thread about the fact that standard head gasket/bolts is best for 99% of people on here and that you will struggle to hold a cam together and that the best bet is a Newman one with solid lifters!
Oh and that the best Intercooler is GRS! PMSL.
Or perhaps we can enter the Guiness Book of Records for the largest amount of threads about the same subject! LOL.
lol its easy for you old skool boys though this is my first "turbo" car ive owned after driving a xe nova so im not used to changing and worrying about blowing headgaskets lol
Good luck with your RST!
I'll always help if you need advice, even if I do sound like I'm taking the piss!! LOL.
use the search function as there are some very useful topics that cover most common issues/upgrade of common rst parts.
a wealth of info and plenty you can learn on here if you look enough.
as far as worrying about the head gasket compared with your nova- do it right and you'll only do it once at moderate power levels
don't forget a skim of the head just to be sure as well.
Mc5506
Oct 5, 2015 09:57 PM
