guide to changing actuator?
Old Nov 10, 2008 | 11:32 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Default guide to changing actuator?
replacing my standard one on S2 for a -31, but never done it before!
Anyone fancy explaining how to do it? Thats if its a hard job! Oh and does it need to be set before i put it on or that?
cheeRS
Old Nov 11, 2008 | 11:03 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
make sure ya engine is COLD!!!!otherwise u WILL get burnt!!jack the car up,with an axle stand,you no good to anyone with no head.
if u look up u will see it looking at ya,its got 2 11 nuts on it,and the wastegate side should have a pin,some dont,depends.
when setting the new one,the wastegate post should be half visible,like half moon,so u just have to pull it a bit to get it over.
Old Nov 11, 2008 | 11:23 AM
B16CVH's Avatar
B16CVH
While you at it, disconnect the battery otherwise your gonna be seeing loads of sparks cuz you are bound to catch the starter at some point!
Old Nov 11, 2008 | 06:34 PM
Zetec_mk4_XR3i
cheers lads - dont sound too hard
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
coscor86
Sep 20, 2015 01:21 PM
marky_g
Sep 12, 2015 04:26 PM
