Bigger injectors
Old Nov 9, 2008 | 06:14 PM
Tiz's Avatar
Tiz
Some sort of seed
Default Bigger injectors
Hey all,
My S1 is running gotech EFI management and cossie injectors, been out road mapping the car and to get anywhere near my desired air fuel ratio of around 12.9(best for power, dont care about fuel economy lol). They are going way beyond a safe duty rate of 75% and flowing around 88% and sometimes 105% which is obviously not good and making it run lean and hot when the injector cant flow the fuel.
Its currently running 2wd sierra injectors(yellows) which i believe are 330cc.
What injectors should i upgrade to? Not planning on doing any more power mods as this will be pretty rapid as it is am i looking at 4x4 injectors or escos? They should also go straight into my fuel rail and inlet considering its been modified to take the yellows no?
Thanks.
Old Nov 9, 2008 | 06:21 PM
Bryan_RST's Avatar
Bryan_RST
Smile
hi there i am gotech mfi pro and i am running 803 dark greens and i am running 218bhp and it is fine
Old Nov 9, 2008 | 06:56 PM
B16CVH's Avatar
B16CVH
You would be fine the green injectors but it is these that flow 330cc/min.
I would of thought the yellows would have been fine though? If they can run a 2.0L 16v Cossie at around 270bhp, they should be fine......???
Tiz's Avatar
Tiz
Some sort of seed
what sort of duty rate they running at mate? As i should be around the 280 mark when mapped.
Old Nov 9, 2008 | 07:22 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I run 630cc Siemens (high impedance). My car idles perfectly at 14.7-15.0:1.
630cc may sound like overkill, but you might aswell have them big enough since there are no side effects.
(I have a brand new set for sale by the way!!).
Old Nov 9, 2008 | 07:25 PM
GaryEvo's Avatar
GaryEvo
i have a set of 1200cc's that might be of use,
Old Nov 9, 2008 | 07:26 PM
Tiz's Avatar
Tiz
Some sort of seed
I would have thought they would be fine but they definately aren't have tried many different things and as soon as i drop the fuel down so the injectors arent going beyond 75% the air fuel ratios are massive.
Old Nov 9, 2008 | 07:28 PM
Christian and Beccy
#1 in Spelling Club
AFPMSL.
They are like TAPS.
Bet you can't get them fuckers to idle nicely.
Old Nov 9, 2008 | 07:36 PM
Tiz's Avatar
Tiz
Some sort of seed
Will they work straight away with my rail and inlet? dont really wanna mess around with anything else really. Oh and how much ?
Old Nov 9, 2008 | 07:38 PM
Christian and Beccy
#1 in Spelling Club
They are identical fitment to Bosch injectors and have the same connectors. The only issue would be whether or not your ECU can run high-impedance.
I'm looking for £200 plus postage.
Old Nov 9, 2008 | 07:39 PM
Christian and Beccy
#1 in Spelling Club
https://passionford.com/forum/ford-rs-turbo-parts-for-sale/267239-siemens-630cc-injectors.html
Old Nov 9, 2008 | 07:42 PM
Tiz's Avatar
Tiz
Some sort of seed
hmmm i'll have to find out about my ECU but i think i might get some cheaper second hand or recon units cant afford to spend £200 on injectors at the moment.
Old Nov 9, 2008 | 07:45 PM
Tiz's Avatar
Tiz
Some sort of seed
so what injectors are avaliable for around the 400cc mark then?
Old Nov 12, 2008 | 03:58 AM
stuart collins's Avatar
stuart collins
give jamie a ring he will have sum in that will do wat u want
Old Nov 13, 2008 | 08:24 PM
Rick's Avatar
Rick
Gotech resolution is shit, so stick a set of greens in.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Fordmad!
Sep 29, 2015 07:03 PM
