Saph 4x4 klunk
Got a problem with my saph 4x4. When i go over a speed bump or now and again when driving i`m getting a klunk from the front end. Thought it could be bushes so replaced them with powerflex jobbies but said klunk is still there
Going to get it on the ramps at my mates garage in morning, what should i be checking/looking for as its got my head done right in. Thanks
Thanks for replies lads, had it on ramps and it looks like its the OS suspension top mount thats goosed. So ordered a new pair and hopefully that`ll sort out my dreaded klunk lol
Hope you get it sorted mate.I would check the 19mm nut on the top of your engine mounts cause i checked mine when i first got my cossie and the drivers side was loose.
Will do Glenn cheers, had a quick look at them and there collins group A ones, they look ok but i`ll double check tomorrow when i do the top mounts. Thanks mate
