rs turbo s2 1990 missfire
Old Nov 7, 2008 | 07:35 PM
ianmorgan50's Avatar
ianmorgan50
Default rs turbo s2 1990 missfire
hi guys
rite heres the prob please help if you can
car starts fine but missfires on boost and somtimes cuts out coming off of boost then when it get hot it wont start untill its cold again, by the look of the plugs it over fueling so i thought it might be the cold start valve so i disconected the fuel line to it and blanked it off but theres no change its still doing it also when it get hot it will miss and judder all through the revs
thanks in advance
Old Nov 7, 2008 | 09:10 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
sounds like leads,get some ford motorsport leads with motorcraft plugs should sort the problem
Old Nov 8, 2008 | 12:43 AM
ianmorgan50
just put new plugs, leads, dizzy cap, and rotor arm on it
Old Nov 8, 2008 | 10:42 AM
marky_g's Avatar
marky_g
Fleet Manager
misses on boost, check all the boost pipes are on tight sounds like a boost leak
mine did it once missed like a bastard on boost like nearly shot me through the windon turned out i'd left a pipe undone
Old Nov 9, 2008 | 10:56 AM
ianmorgan50
checked all that i took the plugs out and there all black so i think its over fuelling
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
