how to check lsd gearbox
Old Nov 7, 2008 | 03:56 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
Default how to check lsd gearbox
i've read verious articles and there seems to be differences in opions
some say
with bar = lsd
without bar = non lsd
others say
with bar = no lsd
without bar = lsd
i've now broken 4 - 5 xr3i cabs and got about 4 gearboxs laying around so need to check what kind of boxs they are as 1 - 2 of them came outta turbos ( thought all turbos came with lsd )
thanx guys
taz
Old Nov 7, 2008 | 04:27 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
if the hole is the size of a 5p with no bar its an lsd
if it has a bar across a bigger hole its a shitter
Old Nov 7, 2008 | 04:35 PM
addiction's Avatar
addiction
there is no difference of opinion as far as i'm aware!
diagonal rod through the diff casing means NO lsd.
No diagonal bar means it has an lsd!
ALL Escort RST's came with an lsd box as standard!!!
Old Nov 7, 2008 | 04:38 PM
KSA-Cossie's Avatar
KSA-Cossie
As above,rod means no lsd.
Old Nov 7, 2008 | 04:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yup as above!
Old Nov 7, 2008 | 06:53 PM
robj20's Avatar
robj20
Jack it up, turn a wheel if the other wheel goes the opposite way its lsd.
Old Nov 7, 2008 | 09:44 PM
WRCjames's Avatar
WRCjames
I thought that if the wheel goes the same way then its LSD. and make sure its outta gear when ya test it!
Doesnt make any difference here anyway as the boxes are out of the car anyway!
Old Nov 8, 2008 | 03:53 AM
taz1787's Avatar
taz1787
cheers guys will have a check when next down lock up
Old Nov 8, 2008 | 08:50 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
yep no bar,then its lsd
Old Nov 8, 2008 | 01:42 PM
robj20's Avatar
robj20
Yes my mistake.
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 24, 2015 11:11 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Bransby
Sep 11, 2015 09:12 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
