bd14 cams on mechanical lifters?
Nov 7, 2008 | 12:15 AM
can i use them? or must i use cams for solid lifters?
Nov 7, 2008 | 07:17 PM
you can but its not ideal,
proper solid spec cams are the way to go
Nov 8, 2008 | 03:16 AM
Nov 8, 2008 | 11:56 AM
speak to martin at reyland
Nov 8, 2008 | 10:02 PM
Quote:
Originally Posted by
coachworz
You can use solids but You lose 0,2-0,25mm lift (clearence) and also quit many degrees of open time.
Nov 9, 2008 | 07:38 PM
Or i can get you ground a solid version of a BD14.
Nov 16, 2008 | 11:38 AM
legend289
what would the power be like and max rev for bd14?
Nov 16, 2008 | 11:18 PM
Mine will rev to 7.5 with solid lifter version - maybe more but I dont want to overdo it.
Nov 16, 2008 | 11:20 PM
i rev to 7800 on hydraulics,
solids are capable of up to 10000 rpm, like karls motor
Nov 17, 2008 | 01:31 AM
*** Sierra RS Custard ***
Although not ideal on solids as you lose a little bit of duration and lift from the needed clearance, at the END of a track session, you'll have more lift than on a set of hydraulics I suspect!
Nov 18, 2008 | 01:37 AM
what wold be a good cams to go with soild lifers as to take advantage of the higer revs..
Nov 18, 2008 | 01:38 AM
tankybaby66
Feb 6, 2016 02:24 PM
20/20 vision
Sep 29, 2015 11:27 AM
