Arch rolling/clearance?
Old Nov 6, 2008 | 10:00 PM
benporter's Avatar
benporter
Default Arch rolling/clearance?
Old Nov 6, 2008 | 10:03 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
What offset and what size tryes are you running ?
Old Nov 6, 2008 | 10:13 PM
benporter's Avatar
benporter
Old Nov 7, 2008 | 04:04 AM
captiva's Avatar
captiva
Originally Posted by benporter
Any pics of sapph 4x4 with the arches rolled? and any advice on getting my arches rolled as im having clearence trouble front and rear on 18'' mos
thanx
We use a baseball bat over here, just stick it between the wheel and the fender (wing) and get someone to drive the car forward slowly letting the bat slip through your hands. Perfect every time, takes minutes.
Old Nov 7, 2008 | 07:07 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine are et35 215/35/18 and didn't have to mod arches m8 onlythe front koni's.
Old Nov 7, 2008 | 08:10 AM
benporter's Avatar
benporter
Old Nov 7, 2008 | 08:40 AM
cossie daz's Avatar
cossie daz
when i had escort cos wheels on my saff i had same problem.had the rear archs replaced in bodyshop i drove out and they rubbed,had them trimmed back but front rubbed so you prob need them trimmed.
most alloy wheel companys will be able to do it but at a price!
Old Nov 7, 2008 | 06:16 PM
cossiegreg1's Avatar
cossiegreg1
you need to check offset, i got a mint solution that will get rid of your arch rubbing problems.......
sell the wheels to me.(serious)
Old Nov 7, 2008 | 09:29 PM
Char1ie's Avatar
Char1ie
I tried everything on my Sapph recently including the baseball bat method. Beware, you will fuck up your bodywork! I have cracked paint and folded inside lips on my arches. Get a professional. And even then be prepared for cracked paint.
Charlie
Old Nov 8, 2008 | 05:05 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Yes my front arches look like shit, rolled to the max and some, still catches. 215/40/17 with Yokohama Paradas which I think are the problem. Offset 35 so that's supposed to be right for a Saff.
Old Nov 8, 2008 | 07:00 PM
benporter's Avatar
benporter
Old Nov 9, 2008 | 12:47 AM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
Thats very strange as mine dont rub at all at the back even with 4 people in the car only used to rub on the front arches a little and i just rolled the lip myself.
Old Nov 9, 2008 | 09:15 AM
benporter's Avatar
benporter
Old Nov 9, 2008 | 02:41 PM
TurboShed's Avatar
TurboShed
Cossiemodo
I think shell rigidity plays a factor. My Saff has a lot of miles on it, think it'd benefit from strut brace/s. It's only the front that rub, the rear have always been fine.
Old Nov 9, 2008 | 04:50 PM
Tony Rs's Avatar
Tony Rs
What springs do you have you your car? coilovers??
Hello mate its on Koni shocks and Eibach springs never even had to mod the koni spring seat
Old Nov 9, 2008 | 08:45 PM
benporter's Avatar
benporter
Old Nov 11, 2008 | 03:28 PM
captiva's Avatar
captiva
Charlie
We use the handle end of the baseball bat first as it is thinner and then gradually move the bat in over a few go's, We don't crack paint but then again we are professional
Old Nov 11, 2008 | 08:33 PM
Char1ie's Avatar
Char1ie
You've done this on a Sapphire?
Cos when I tried the pull at the front caused the back to pull in and vice versa - back and forth just caused cracked paint and almost no arch stretch, also the lip folded in and creased. My car is very low and now my arches are very screwed. It's OK though.
Charlie
Old Nov 11, 2008 | 08:47 PM
DaveCrack's Avatar
DaveCrack
I used this for rolling the arches:
If you roll the lip very slow and heat it up a bit the paint also doesnt crack.
Old Nov 11, 2008 | 08:55 PM
rob741's Avatar
rob741
i have koni shocks with avo springs had mine rolled at moorlands doesn't catch 35 offset
Old Nov 11, 2008 | 08:57 PM
benporter's Avatar
benporter
Old Nov 11, 2008 | 09:15 PM
rob741's Avatar
rob741
moorland classics its not mate but worth getting it done propley, they rolled the arches the paint nearly always splits so painted and also modded inner arches so they still fit propley, had no problems. the wheels are mm off the konis but dont catch
RSMK4TURBO
Aug 17, 2014 09:42 PM
Dearo
Mar 19, 2012 10:13 AM
adam rs
Oct 26, 2006 08:43 AM
