braided loom ,500 cooler, 205 short motor
Old Nov 5, 2008 | 06:50 PM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
Default braided loom ,500 cooler, 205 short motor
pectal style loom mint condition, only had 3-4000 miles use . £250 posted
Pace rs500 intercooler saff/sierra, good condition £225.
205 bottom end on .5 bore , wire rung. 18 months ago had a strip down, check over and rebuild from Longmans engineering. No knocks, rattles or smoke.
OFFERS£££££
Old Nov 9, 2008 | 09:50 PM
Lo@der's Avatar
Lo@der
up
Old Nov 9, 2008 | 10:53 PM
moonstone_cossie's Avatar
moonstone_cossie
how much for loom?
Old Nov 10, 2008 | 09:39 AM
Lo@der's Avatar
Lo@der
Sorry , £250 posted
Old Nov 17, 2008 | 11:08 AM
Lo@der's Avatar
Lo@der
Loom was running with coil and std setup.(i.e no closesd loop or wasted spark)
Old Nov 26, 2008 | 03:48 PM
Lo@der's Avatar
Lo@der
bump
Old Nov 27, 2008 | 02:34 PM
sortedsaff's Avatar
sortedsaff
price on bottom end please mate
Old Nov 27, 2008 | 04:08 PM
Lo@der's Avatar
Lo@der
p.m sent
Old Nov 27, 2008 | 05:59 PM
Lo@der's Avatar
Lo@der
Loom and a few bits on ebay
http://shop.ebay.co.uk/merchant/loader5710
Old Nov 28, 2008 | 07:16 AM
cossie daz's Avatar
cossie daz
hi mate,
is the loom standard fit?? is it a replacement for standard loom ??
Old Nov 28, 2008 | 10:23 AM
Lo@der's Avatar
Lo@der
Originally Posted by cossie daz
hi mate,
Yes it is mate, i.e runs with webber ecu and sensors, coil and dizzy no closed loop or secs monitor wiring.
Though Ryan could modify it to run twin amps for wasted spark, secs lead and closed loop if you wanted.
Currently tps wires in 2wd position for pf01 and L6, but agian the wires can easily be swapped roung for L8 and pf09.
Old Nov 28, 2008 | 05:45 PM
cossie daz's Avatar
cossie daz
Not sounding stupid but when you say 2wd position pf01,l6 can be swapped do you mean the big plug that goes on the back of ecu?
e.g different pin connection set up on l6 and l8??
Old Nov 28, 2008 | 05:57 PM
Lo@der's Avatar
Lo@der
If you have a 2wd car with a 2wd ecu (L6), 2wd throttle position sensor (pfo1) and you wish to run an L8 ecu (4wd) you have to change to a 4wd throttle position sensor (pf09) and to make it work with a 2wd loom as the above is originally, you switch the two wires around going to the throttle position sensor.
But you only have to do this if you wanna run an L8 ecu on a 2wd.
Old Nov 28, 2008 | 06:43 PM
cossie daz's Avatar
cossie daz
cheers mate i understand abit better now.i will be running a L6 for a while but will be changing to a L8 later.
When you say turn the TPS wires round what do you mean by this ?
Thanks
Old Nov 28, 2008 | 07:30 PM
Lo@der's Avatar
Lo@der
Swap the wires in the plug round, ie left wire in the place of the right and the right in the place of the left.
Old Dec 13, 2008 | 11:53 PM
joe s's Avatar
joe s
Have you got any pics of the cooler mate?
Old Dec 14, 2008 | 09:26 AM
ellicoss's Avatar
ellicoss
Pm me a price for bottem end mate cheers
Old Dec 14, 2008 | 03:11 PM
Lo@der's Avatar
Lo@der
sorry bottom end and loom now sold.
155lee
Oct 27, 2015 04:55 AM
muzzman1
Sep 30, 2015 08:59 PM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
Billy_RS
Sep 13, 2015 04:17 PM
