Lower arm pinch bolt
Once the nut is off one side should I be able to bash the pinch bolt through the hole or will I also need to undo it using the torx head?
I dont know if the hub is threaded or not...
I only ask as I've got the nut of easily but not started undoing the bolt due to not having a torx bit to use.
if u want any replacements for any other suspension bolts, gimme a shout, ive got loads left over from my rebuild, 1s where iv had to buy 5 at a time etc
genuine aint the cheapest way to buy bolts, but it is nice n bufty at least lol
Always the way.
lol..
If only I'd posted this sooner.
Thanks for the offer. Hopefully I wont need any, just done both struts and arms - theres not a lot left to replace now. (famous last words...
lol..
DavidK
Sep 27, 2015 02:55 PM
