2wd wheel bearings.
Old Nov 4, 2008 | 07:04 PM
borderfox's Avatar
borderfox
Default 2wd wheel bearings.
Is there anywhere i can buy these bearings without the dreaded cosworth tax......
Are they the same both sides only the nut being handed........
Old Nov 4, 2008 | 07:05 PM
kellyalfie's Avatar
kellyalfie
burton power in ilford essex
Old Nov 4, 2008 | 07:06 PM
KSA-Cossie's Avatar
KSA-Cossie
Not 100% sure m8 but i replaced both on my 4x4 saph and they were fooking dear !!!
Old Nov 4, 2008 | 07:09 PM
Might be better off buying high speed bearings from bearing supplier if they are silly money ?
How much are they normally then ?
Old Nov 4, 2008 | 07:27 PM
borderfox's Avatar
borderfox
30 Pound plus post to Ireland. Road in other words.
I tried a good bearing shop and they could not track them down....
Won't mind its a SKF bearing i have and there a big brand.
Old Nov 4, 2008 | 07:45 PM
cossie604's Avatar
cossie604
I bought mine from my local PartCo motorfactors.
Old Nov 4, 2008 | 08:15 PM
borderfox's Avatar
borderfox
Whos partco are they a auto parts place....
Old Nov 4, 2008 | 08:38 PM
cossie604's Avatar
cossie604
Yeah just an average motor factors. Have you tried your local factors? They were even in stock complete with handed nuts etc.
Old Nov 5, 2008 | 03:16 AM
oohogwash1's Avatar
oohogwash1
I went to a bearing supply house here in Australia, I found that the front bearing set is a common ford size. The rears were a special size which I have to buy direct from UK.
Regardless I suggest you take in the seals and bearings as I did as that is the best way to buy these kind of bearings. The numbers do not lie.
Regards
Gavan
Old Nov 5, 2008 | 05:48 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the rear bearings are the same for any sierra/granada so you won't need to pay there, but make sure youget the ones with the metal cage rather than the plastic, because they tend to break when you try and remove them, spilling their inards all over the floor
the front ones i found were difficult to locate and, if you do the nut up too tight, tend to easily strip the threads off the cv's
Old Nov 5, 2008 | 05:34 PM
cossie604's Avatar
cossie604
Old Nov 5, 2008 | 06:21 PM
dojj's Avatar
dojj
done 3, wrecked 2
Old Nov 5, 2008 | 06:30 PM
cossie604's Avatar
cossie604
2wd cossie's dont have front constant velocity joints you dumb ass
Old Nov 5, 2008 | 06:36 PM
borderfox's Avatar
borderfox
After getting a price in my auto part shop today.....
87euros plus vat.......Each......
Old Nov 5, 2008 | 06:51 PM
cossie604's Avatar
cossie604
http://cgi.ebay.co.uk/GGR889-Coswort...1%7C240%3A1318
http://cgi.ebay.co.uk/GGR890-Coswort...1%7C240%3A1318
Old Nov 5, 2008 | 07:05 PM
dojj's Avatar
dojj
i know, but he never said front or rear, and i was also refering to my wrecking of one 2wd front (which also chewed up the abs sensor so cost me more than it should have )
Old Nov 5, 2008 | 07:30 PM
cossie604's Avatar
cossie604
He may have not said front or rear but you said that the fronts tends to strip the threads off the cv's
cossie604's Avatar
cossie604
He may have not said front or rear but you said that the fronts tend to strip the threads off the cv's
Old Nov 5, 2008 | 07:31 PM
cossie604's Avatar
cossie604
I repeated my self
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Old ford
Jul 31, 2015 06:50 AM
