body to change sierra sapphire 4x4
Old Nov 3, 2008 | 07:50 PM
21turbojon's Avatar
21turbojon
Default body to change sierra sapphire 4x4
Hello, I am writing from spain because I had an accident with my ford sierra sapphire cosworth 4x4 1992 4-door. I need to know whether the body of any other mountain range 4-door version that is not cosworth or 4x4 I would change the entire mechanical system of a car to another. Here in Spain I have heard that changes the sunroof (not any serious problem) and say they can not attach the 4x4 change that will not fit into a normal body saw.
I hope if anyone of you had me echo that report. thank you very much
Old Nov 3, 2008 | 08:07 PM
The Youth.'s Avatar
The Youth.
you will need to cut out the front chassis rails to allow for the front driveshafts just look above your shafts in the cosworth and you will see the half moon shaped cut outs.
steve
Old Nov 3, 2008 | 08:44 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the later 90 spec onwards sierra shell will basicly take the cosworth everything
other than the cut outs in the front chassis rails
Old Nov 3, 2008 | 09:45 PM
westus1's Avatar
westus1
a lot of the late shells had the arches already in the front chassis legs
SmudgerByName
52
Jul 28, 2016 06:14 PM
charliecosworth
Aug 19, 2015 02:00 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
cossie4x4
Aug 14, 2015 06:29 PM
Old ford
Jul 31, 2015 06:50 AM
