Breather filter fitted on the rocker cover
Old Oct 29, 2008 | 08:02 PM
Butchi's Avatar
Butchi
Default Breather filter fitted on the rocker cover
I have fitted a breather filter on my rocker cover. Now I have got a new problem in my car. The hole car smells old oil from the breather filter. It smells awful inside the car and also outside the car. When I have parked the car in a parking spot, people turn around and lookes at me and my car.
You guys that also got a breather filter fitted on the cover, do you have the same problem?
BR Butchi
Old Oct 29, 2008 | 08:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yup!
Thats the problem with venting crank case pressure to atmosphere!
Old Oct 29, 2008 | 09:05 PM
Butchi's Avatar
Butchi
So you have the same problem?
Old Oct 29, 2008 | 09:39 PM
Chris69's Avatar
Chris69
yours sounds a bit extreme but you do get use to it- mobil 1 smells quite nice after a while
Old Oct 29, 2008 | 10:16 PM
Jimmyc's Avatar
Jimmyc
Why not fit a bailey breather kit & vent to a catch tank instead?
Should overcome the smell, and improve breathing.
Old Oct 30, 2008 | 07:58 AM
Butchi's Avatar
Butchi
Where can I get a kit from?
Old Oct 30, 2008 | 08:05 AM
fish99's Avatar
fish99
Lots of Motorsport companies do them
http://www.randbmotorsport.co.uk
http://www.burtonpower.com/company_info.aspx
Old Oct 30, 2008 | 03:36 PM
Butchi's Avatar
Butchi
How does those catch tanks work? Is there a connecter to fit a breather filter to those tanks?
Old Oct 30, 2008 | 03:42 PM
Chris69's Avatar
Chris69
they work by collecting the oil passed through the breather hole and re-circulating it back down to your sump- they will also require a filter of some sort but will not smell half as much if at all
Old Oct 30, 2008 | 06:53 PM
EssexMikeSi's Avatar
EssexMikeSi
What is it you've put on there? is it a oil seperator? Thats what i have and 2 pipes from the rocker go to it, the other goes down to the metering unit then the other goes down to the bottom of the block for the oil return, oh and then a vacuum pipe goin from the oil seperator to the left outlet on the inlet manifold.
Old Oct 30, 2008 | 06:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate mine smells too!
I am using the bailey breather/seperator kit but instead of sending the oily air back to the metering unit it vents to atmosphere, hence the smell!
Old Oct 30, 2008 | 10:27 PM
EssexMikeSi
Karlos, is it not good to have it going back to the metering unit then??
Old Oct 31, 2008 | 08:25 AM
Rick's Avatar
Rick
no, as the oil can cause det for one, it's legal emissions requirement though. You should have a seperator, and then vent this with a pipe to the back of the car.
Old Oct 31, 2008 | 01:37 PM
orionmojo's Avatar
orionmojo
i thought it was illegal to vent to the atmosphere?
Old Oct 31, 2008 | 02:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As Rick says!
Old Oct 31, 2008 | 05:11 PM
JamboRS's Avatar
JamboRS
focus rs 1672
just run a pipe from the breahter return and vent it under the car,thats what i done,still get some oil smell when sittin in traffic but leasy its no pouring fumes in thru the vents
Old Oct 31, 2008 | 05:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I was thinking of doing exactly that!
Old Oct 31, 2008 | 05:45 PM
Rs-Simon's Avatar
Rs-Simon
Thats what I have done. Keep it out the way of the driveshafts thou .
JoeyBoyden
20
Aug 22, 2015 03:23 PM
3doorcozmess
Aug 21, 2015 11:17 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
